Kerry Hunter Headers: Problem!, clutch cable routing |
Nor.Cal.914 |
Nov 17 2009, 05:23 PM
1975 914 3.0SC Group: Members Posts: 1,050 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None |
So, I tried researching threads on the Kerry Hunter Header system to figure this out for myself, but no such luck. I just recently installed a set of Kerry Hunter's and have toasted one clutch cable and am possibly on the verge of doing it again to another one. The first one I ruined was from improper routing which caused an unnecessary kink where the cable comes out to go around the plastic wheel in the rearward area of the transmission. I ran the new cable what I thought was the right way, but it still seems like something is wrong because I'm melting my outer lining on my cable. I wrapped the headers in heat wrap to try and allow the cable to run through cylinders 4 and 3's header. It seemed like it was working but I just took a look at it yesterday and it definitely appears to be slightly melting the outer coating on the cable. I was told that wrapping the cable itself in heat wrap is worse because it traps the heat inside and melts the cable even faster. So... What do I do? There appears to be a kink in cylinder 4's header that seems like it would only be there to allow the clutch cable to run through, but I'm not entirely sure. The new cable I bought is a heavier duty cable that allows a bit more flexing than my previous one so it MIGHT be possible to run it under the headers, but that was how I ran it the first time and it shredded the not-so-heavy-duty previous cable. Any advice would be great as I would like to avoid replacing this cable again, if possible. Please let me know (IMG:style_emoticons/default/thumb3d.gif) Thanks
-Chris |
ChrisFoley |
Nov 17 2009, 09:19 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Thanks Ken!
Tangerine Racing Clutch Pulley Adapter |
Lo-Fi Version | Time is now: 8th June 2024 - 04:12 PM |
