RMally |
Newbie ![]() Group: Members Posts: 24 Joined: 25-October 09 From: Tennessee Member No.: 10,977 Region Association: South East States ![]() |
Is there a complete weather stripping set that anyone sells, or is it just by the piece or section.
Besides pelican, where can you buy weather stripping for the 914. Thanks, |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I couldn't resist but take a look at this
16 Piece Rubber Kit includes: My World price Windshield to top seal $179 Left roll bar vertical seal Right roll bar vertical seal $36 Left top to sode seal Right top to side seal $38 Left outer door seal Right outer door seal $74 Left inner door seal Right inner door seal $32 Front hood seal Both seals $80 Rear trunk seal Both seals $47 Engine lid to trunk seal $26 Fender to cowl seals (2) $7 Left outer door glass wiper strip Right outer door glass wiper strip $12 Rear roof seal $40 If you check the math $571 and you get the bulkhead seals for both trunks. I'll offer you the same kit at 50% off $1285 (IMG:style_emoticons/default/biggrin.gif) To be fair, my seals are not OEM, where the Zim's my be al OEM. I have made some modifications, such as aluminum internals on all. These numbers do include the ends "cut and plugged" on mine. I do have the lower front targa seal,the lower dash to windshield, the deck lid welting and door handle isolators. These would make it a more complete kit. I personally would replace the triangle window seals in the doors ( I do not have but they are under developement, and I should have in 6-8 weeks). As well as the front turn signal seals, George at AA has those now. And George's kit is more reasonably priced I have put together packages for several members in the past, the only problem is that you sometimes you get seals you don't need. If anyone wants a "package" I would be happy to put one together for your specific aplication. I typically can knock a few bucks, but as you can see my margins are not huge. If I'm out of line on this I'll edit or remove my post, but it just isn't a screaming deal. |
Lo-Fi Version | Time is now: 16th June 2024 - 10:05 AM |
