| Cheapsnake |
Nov 21 2009, 06:52 PM
Member ![]() ![]() Group: Members Posts: 419 Joined: 15-November 07 From: Door County, WI Member No.: 8,341 |
I just saw a thread on a water pump failure and there was a comment about electric wp's being not a good choice due to their lack of longevity, intended mainly for drags and short runs.
I'm just about to install an electric pump in my Rover 3.5 conversion when I saw that, but before I do I'd like some input from those that have had real experience, good and bad with electric pumps. and while you're at it, throw some make and model out there. Tom |
| Cheapsnake |
Nov 23 2009, 08:23 AM
Thanks Jamie, you just dashed my hopes for just ONE job that didn't require hacking and welding. (IMG:style_emoticons/default/headbang.gif) However, since you've been there, I have to give some credence to your predictions.
Mark, do you have any more info on that pump you're using? It looks just like what I have in mind, but they are not too common an item. Drive-ability, the engine is a Rover 3.5L, the LT-1's little aluminum brother. It's actually a British reincarnation of the Buick 215 that Jamie is running. I'm building "the mutt", 3.5 block, 4.0 heads and headers (higher compression, better flow), Buick timing cover, valve covers, intake manifold and oil pan, ...... With a boosted cam, higher compression and a few other tweaks, I'm guessing to be in the 200 - 210 hp neighborhood - just enough to get me in trouble. I've been promising Jamie pics for some time now but every time I think I can actually finish a job worthy of pics, the mutt throws me a slider. However, I think I'm through the hard stuff and hope to have the tranny mounted this weekend and THAT will be an occasion for pics. Stay tuned. Tom |
| JRust |
Nov 23 2009, 08:58 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Thanks Jamie, you just dashed my hopes for just ONE job that didn't require hacking and welding. (IMG:style_emoticons/default/headbang.gif) However, since you've been there, I have to give some credence to your predictions. I've been promising Jamie pics for some time now but every time I think I can actually finish a job worthy of pics, the mutt throws me a slider. However, I think I'm through the hard stuff and hope to have the tranny mounted this weekend and THAT will be an occasion for pics. Stay tuned. Tom It may be doable Tom. I think with the right pulley in front of the harminic balancer you can move it back some. Mine is a dbl pulley with the belt on the outside to line up with my pump. I am sure without my water pump as it sits I could move that back at least another 1/2-3/4". It might work but it will be very close to the firewall there. My alternator also comes through the firewall. Again that is part of the overall belt driven system as it sits. I would still recommend the tranny adapters as it will only make the space issue up front a little easier to deal with. (IMG:style_emoticons/default/idea.gif) |
Cheapsnake V8 guys, Electric water pump? Nov 21 2009, 06:52 PM
drive-ability My thoughts are if you drive your car every day an... Nov 21 2009, 07:18 PM
Bruce Hinds Yeah me too! I've been interested in this... Nov 22 2009, 12:22 AM
zymurgist Are there any manufacturers using electric water p... Nov 22 2009, 12:33 AM
914junkie I'd like to here some solid feedback on this a... Nov 22 2009, 12:46 AM
JRust Meziere make a nice electric pump. It has a life e... Nov 22 2009, 01:17 AM
sean_v8_914 find 914GT from Tucson, he has one. last time we s... Nov 22 2009, 09:34 AM
Cheapsnake Now I'm thinking, as an option a remote belt d... Nov 22 2009, 05:44 PM
drive-ability
BTW, I gutted the stock pump of its impeller and ... Nov 22 2009, 08:56 PM
JRust
Now I'm thinking, as an option a remote belt ... Nov 22 2009, 11:34 PM
Bruce Hinds BTW, I gutted the stock pump of its impeller and c... Nov 23 2009, 01:06 AM
marks914 I stick with the belt-driven for a couple of reaso... Nov 23 2009, 06:50 AM
computers4kids Renegade
$335 WATER PUMP AND ASSEMBLY: Remot... Nov 23 2009, 09:03 AM
marks914
Mark, do you have any more info on that pump you... Nov 24 2009, 07:49 AM
JRust http://www.britishv8.org/Articles/Shortie-Water-Pu... Nov 23 2009, 04:14 PM
burton73 As you guys are going length of engine and the fir... Nov 23 2009, 06:00 PM
Cheapsnake
As you guys are going length of engine and the fi... Nov 25 2009, 07:58 AM
computers4kids
As you guys are going length of engine and the f... Nov 25 2009, 10:29 AM
charliew The lt1 motor has a cam drive waterpump and also h... Nov 24 2009, 10:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:58 PM |
