| Cheapsnake |
Nov 21 2009, 06:52 PM
Member ![]() ![]() Group: Members Posts: 419 Joined: 15-November 07 From: Door County, WI Member No.: 8,341 |
I just saw a thread on a water pump failure and there was a comment about electric wp's being not a good choice due to their lack of longevity, intended mainly for drags and short runs.
I'm just about to install an electric pump in my Rover 3.5 conversion when I saw that, but before I do I'd like some input from those that have had real experience, good and bad with electric pumps. and while you're at it, throw some make and model out there. Tom |
| burton73 |
Nov 23 2009, 06:00 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,989 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
As you guys are going length of engine and the firewall. Rod Simpson told me that the fire wall needed to be dented in a place on the driver side of the car where the valve cover will just hit it. He said it does not need that much but around 1/2 inch or so of a dent. I will get a picture of it and measure it before I do my car.
I am still not sure on the pump idea but Bruce has 80,000 miles with only one bearing problem and Mark has no problem with 40,000 miles those are good numbers. Yes they’re where some problems on some of the guys’ cars and that makes me worry but I think I would be more worried something different would fail with the new trick system. . Bob |
| Cheapsnake |
Nov 25 2009, 07:58 AM
As you guys are going length of engine and the firewall. Rod Simpson told me that the fire wall needed to be dented in a place on the driver side of the car where the valve cover will just hit it. He said it does not need that much but around 1/2 inch or so of a dent. If it does become a problem I can take a good 3/4" off the corner of the valve covers and braze in a patch. Works well with stamped steel, cast will be a little more difficult. Denting the firewall sounds like it might be easier but my main concern is being able to get the covers on and off if I need to without dropping the engine. Maybe I'll do both and go for overkill. Tom ps: thought I'd have some pics by now but as I was installing my new alternator on my newly fabbed alternator bracket last night I discovered the geometry is wrong. It comes close to going over-center on belt-tightening, also too close for comfort to the headers. Starting from scratch. But it sure was purty. |
Cheapsnake V8 guys, Electric water pump? Nov 21 2009, 06:52 PM
drive-ability My thoughts are if you drive your car every day an... Nov 21 2009, 07:18 PM
Bruce Hinds Yeah me too! I've been interested in this... Nov 22 2009, 12:22 AM
zymurgist Are there any manufacturers using electric water p... Nov 22 2009, 12:33 AM
914junkie I'd like to here some solid feedback on this a... Nov 22 2009, 12:46 AM
JRust Meziere make a nice electric pump. It has a life e... Nov 22 2009, 01:17 AM
sean_v8_914 find 914GT from Tucson, he has one. last time we s... Nov 22 2009, 09:34 AM
Cheapsnake Now I'm thinking, as an option a remote belt d... Nov 22 2009, 05:44 PM
drive-ability
BTW, I gutted the stock pump of its impeller and ... Nov 22 2009, 08:56 PM
JRust
Now I'm thinking, as an option a remote belt ... Nov 22 2009, 11:34 PM
Bruce Hinds BTW, I gutted the stock pump of its impeller and c... Nov 23 2009, 01:06 AM
marks914 I stick with the belt-driven for a couple of reaso... Nov 23 2009, 06:50 AM
Cheapsnake Thanks Jamie, you just dashed my hopes for just ON... Nov 23 2009, 08:23 AM
JRust
Thanks Jamie, you just dashed my hopes for just O... Nov 23 2009, 08:58 AM
computers4kids Renegade
$335 WATER PUMP AND ASSEMBLY: Remot... Nov 23 2009, 09:03 AM
marks914
Mark, do you have any more info on that pump you... Nov 24 2009, 07:49 AM
JRust http://www.britishv8.org/Articles/Shortie-Water-Pu... Nov 23 2009, 04:14 PM
computers4kids
As you guys are going length of engine and the f... Nov 25 2009, 10:29 AM
charliew The lt1 motor has a cam drive waterpump and also h... Nov 24 2009, 10:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:18 PM |
