How hard is it to wire the car, to remove unnecessary wires |
turnaround89 |
Nov 25 2009, 11:18 AM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
My car has been having some electrical issues over the past year, and some have been tracked down and others have not. I was thinking of wiring the car completely new with my own setup. I would like to make the wiring as simple as possible, basically make the headlights, tail lights, turn signals, fuel pump, and engine turn on. We are trying to remove anything that isn't necessary in the car to make it lighter. can i wire the car and get rid of the relay board?, the car is carbed(if that makes a difference)
I was thinking of using simple SPST, SPDT, etc swtiches for the dash and wiring the car with those. Has anyone wired up there autox cars to a more simplified version? |
turnaround89 |
Nov 25 2009, 09:11 PM
QUOTE One thing missing in the diagram above, i would recommend running a relay between the starter switch and the starter to take the load off the switch itself. since there isn't a starter switch, just replace the starter switch with the relay in the diagram, right? that way the relay is between the ignition sw and the starter jmill - thats what i was planning on doing, i have all winter to wire the car the way i want, so might as well take my time and have it the way i want it to look |
Lo-Fi Version | Time is now: 11th June 2024 - 05:20 PM |
