What is this part?, Do I really need it? |
nsr-jamie |
Nov 28 2009, 03:04 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Hello, got to work on my car a little this Saturday morning and replaced a switch, added one of Marks nice seals and some other smaller things...while I had the fuse box out under the dash I found this part. What is it? Is this the cause of my never ending clicking sound?? The car is always clicking with that sound you know when you turn on your hazards or pull the ebrake handle up...my car never stops clicking when its running...over the years I got use to it and eventually gave up but want to fix this annoying problem. It sounded like the clicking was coming from here. Do I really need this part? What would happen if I disconnent it and left the wires unattached (Don't want any fires, hazards or dangers)...is this switch or box or what ever its called faulty and the cause of my never ending clicking sound??
Here are the pictures, oh yes...the hazards are off and the ebrake all the way down and released and it still clicks even when the red light is not flashing in the fuel meter gauge. Any help would be appreciated and thanks (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
tradisrad |
Nov 28 2009, 10:27 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
Mine was causing both turn signal indicator lights to falsh at the same time. I swaped it out and the indicator lights started working normally.
I bet if you replace it the clicking sound will go away... unless you have another fault that is causing the relay to click. |
Lo-Fi Version | Time is now: 11th June 2024 - 08:04 AM |
