> Question: Plastic clips for fuel lines in engine compartment, etc.
x98boardwell
post Nov 20 2009, 07:04 PM
I am looking for the rubber angled grommets that are found under the battery tray of a 914 which hold the fuel lines steady and from cutting themselves on the metal as they pass through the sub-frame on there way up to meet with the fuel lines that supply the injectors.
Are they still available?
If not, what do you/I use now?
Also, can we still buy the plastic clips which snap into the firewall and hold the fuel lines as well? Mine are white/clear plastic and are very brittle...
I own a 75 914 2.0
Thanks in advance,
Bryan
x98boardwell
post Nov 28 2009, 11:36 AM
Good question. I will address that in a minute. The key is that the clip will also fit in the hole that is already in the metal so they will be in the same location. Does the spark plug wire holders have the same size plug which holds the clip to the metal? If so, then that could work.
Regarding the plastic fuel lines.. mine are still pliable and seem to be in good condition. All of the old cloth style lines in the engine compartment have been replaced but I figure why change them if they look good on inspection and are still pliable and flexible?? Also, how much time is invloved in changing the lines in the engine compartment and the tunnel?
Thanks,
Bryan
x98boardwell   Question: Plastic clips for fuel lines in engine compartment, etc.   Nov 20 2009, 07:04 PM
SirAndy   Last time i checked the rubber grommets were still...   Nov 20 2009, 07:12 PM
x98boardwell   Andy, Any idea on part number? I searched all ov...   Nov 20 2009, 07:18 PM
bdstone914   Andy, Any idea on part number? I searched all o...   Nov 21 2009, 12:28 AM
SirAndy   You can download the latest parts catalog as a PDF...   Nov 20 2009, 07:29 PM
Cevan   It's the same as a VW part. You can get them ...   Nov 20 2009, 08:10 PM
plays with cars   Are these the same part for the fuel lines through...   Nov 20 2009, 08:18 PM
Dave_Darling   Rats, I looked in the catalog and couldn't fin...   Nov 21 2009, 01:25 AM
x98boardwell   Guys, thanks for all the help. I looked all over ...   Nov 21 2009, 08:39 AM
x98boardwell   Here is a picture of the plastic clip.   Nov 21 2009, 08:40 AM
tod914   Plastic clips NLA   Nov 21 2009, 09:17 AM
type47   I found alot of 914 rubber parts in West Coast Met...   Nov 21 2009, 09:17 AM
914Sixer   It is the same as the VW Speedometer grommet used ...   Nov 21 2009, 12:29 PM
x98boardwell   Guys, I'm still looking for a suitable plastic...   Nov 28 2009, 11:03 AM
Geezer914   Try looking for a spark plug wire loom that attach...   Nov 28 2009, 11:18 AM
x98boardwell   Good question. I will address that in a minute. ...   Nov 28 2009, 11:36 AM
Geezer914   West Coast Metric has the spark plug wire looms yo...   Nov 28 2009, 11:57 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:56 PM
