> Hold The Phone! I'm working on MY CAR!, Prepping for paint....
McMark
post Sep 16 2008, 01:14 AM
914 Freak!
I think it was the Tied House meet that gave me the kick in the pants, but I finally decided to jump in and get started on my car. It's been begging for work for a long time. I'm starting with the rear end sections. Can't wait for it to actually DRIVE! (IMG:style_emoticons/default/rolleyes.gif) Here's the list off the top of my head.
1. Pull the motor and fix oil leaks, pull the ceramic lifters, clean everything, install carbs (for now).
2. Fix the hell hole and firewall rust, plus weld all the little holes in the firewall. New battery tray and new rear trunk pivots.
3. Fix the 'access hole' some DAPO cut in the rear trunk. The top starter bolt is not THAT hard to get to. (IMG:style_emoticons/default/dry.gif)
4. Clean and paint the engine bay and rear trunk.
5. Clean and reseal the transmission and replace the speedo angle drive.
Here are the pictures from day one.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
McMark
post Nov 28 2009, 11:11 PM
914 Freak!
I finally finished the one thing that started off this whole madness. (IMG:style_emoticons/default/lol-2.gif)
The new rear trunk pivots are in. I bought stock reproductions, then TIG welded the nut boss to the 'frame'. The welds that came on the parts were obviously crap. One of my TIG welds came out better than the other. (IMG:style_emoticons/default/dry.gif) Once the welds cooled, I used some sandpaper on glass to smooth out the face, since the hinge will pivot on that face, and any 'boogers' will cause wear and could cause future damage.
Then I drilled the holes for the rosette welds and painted the back side of the bracket (since you won't be able to get paint back there later). To weld them in I attach the hinges to the lid with the bolts in the middle of their adjustment, and set everything into place. The I line up the gaps as much as possible and use masking tape along the gaps to help hold everything in place. Then using shims I brace the lid up to the correct vertical height. Getting this part right is THE MOST IMPORTANT, since you won't be able to adjust it later. Then ZAP! (IMG:style_emoticons/default/welder.gif) I used power C and wire feed 5.5 on my Lincoln WeldPak 100 with bi-mix gas for the welding.
Now I can make the final gap adjustments as necessary.
McMark   Hold The Phone! I'm working on MY CAR!   Sep 16 2008, 01:14 AM
watsonrx13   Congrats Mark.... Now, while you're in there.....   Sep 16 2008, 06:03 AM
SGB   That might need a little spacklin' befor ya pa...   Sep 16 2008, 07:12 AM
r_towle   Think about this... Chrome engine bay...... inner...   Sep 16 2008, 07:15 AM
Dave_Darling   Right on, McMark! --DD   Sep 16 2008, 07:44 AM
rick 918-S   WTG Mark!   Sep 16 2008, 08:01 AM
FourBlades   Good to see you are getting going. You are going ...   Sep 16 2008, 08:13 AM
LarryR   Hey, glad to see you are finding some time to work...   Sep 16 2008, 08:33 AM
jgara962   :Qarl: Can't wait to see it on the road   Sep 16 2008, 10:46 AM
greenie   It's about time... you were turning into the p...   Sep 16 2008, 11:12 AM
McMark   Heeheh, LOL. :lol: This will be going back to o...   Sep 16 2008, 12:10 PM
Vacca Rabite   Heeheh, LOL. :lol: This will be going back to o...   Sep 16 2008, 12:47 PM
Dr. Roger   I'm with Zach. Keep it with graffitti and cal...   Sep 16 2008, 01:39 PM
ConeDodger   OMG!!! Isn't it time you put the 2...   Sep 16 2008, 02:21 PM
McMark   Missing heads... :( The 2270 is for the Aubergine...   Sep 16 2008, 06:42 PM
r_towle   Chrome paint the engine bay....do it... Rich   Sep 16 2008, 06:50 PM
Gint   Slacker... :)   Sep 18 2008, 10:54 PM
McMark   Hey, some of us are still working... :P The motor...   Sep 19 2008, 01:54 AM
PanelBilly   How much fun can one person have? When you have a ...   Sep 19 2008, 09:32 AM
RoadGlue   Good work mark! You're inspiring me to pu...   Sep 19 2008, 02:43 PM
sendjonathanmail   :agree:   Sep 19 2008, 09:10 PM
McMark   Cleaned the transmission today. Got most of the n...   Sep 20 2008, 12:03 AM
knuckledrgr914   Cleaned the transmission today. Got most of the ...   Apr 10 2009, 11:40 AM
McMark   More done today. Cutting the old metal out. Noth...   Sep 20 2008, 09:47 PM
LarryR   More done today. Cutting the old metal out. Not...   Sep 20 2008, 10:13 PM
ConeDodger   More done today. Cutting the old metal out. No...   Apr 10 2009, 08:32 AM
Root_Werks   Stop, stop, stop, wait,,,, waaaaaay to much progre...   Sep 20 2008, 09:53 PM
McMark   Do you know if they are early or late? I definite...   Sep 20 2008, 10:17 PM
LarryR   Do you know if they are early or late? I definit...   Sep 20 2008, 10:28 PM
McMark   Sounds good! :thumbsup: My other car is a 72...   Sep 20 2008, 10:34 PM
McMark   A month later, I made a little more progress...   Oct 24 2008, 11:27 PM
rick 918-S   :popcorn: :headbanger:   Oct 25 2008, 12:01 AM
McMark   a little more progress... I got a set of bus carb...   Apr 9 2009, 07:27 PM
SirAndy   Maybe you can try the soda blasting setup on those...   Apr 9 2009, 08:21 PM
McMark   As soon as you come up and help me pull the electr...   Apr 9 2009, 09:14 PM
r_towle   pull them apart and dunk them in a citris based cl...   Apr 9 2009, 09:19 PM
Heeltoe914   Whats up Mark. Good to see you in Sacramento a few...   Apr 9 2009, 10:49 PM
McMark   Here they are:   Apr 10 2009, 12:14 AM
SirAndy   Translation: -------------------------------------...   Apr 10 2009, 12:57 AM
ConeDodger   This FourBlades guy John just has to be stopped...   Apr 10 2009, 08:35 AM
FourBlades   This FourBlades guy John just has to be stopped...   Apr 10 2009, 07:38 PM
McMark   Post a new thread and I'll go into it.   Apr 10 2009, 11:48 AM
dbgriffith75   :blink: All I can say is... WOW! [Okay I ca...   Apr 11 2009, 06:55 AM
McMark   Finished up the patch that I was halfway done with...   Apr 11 2009, 09:15 PM
JRust   Looking good dude! Keep up the good work :danc...   Apr 11 2009, 09:33 PM
Rusty   Looks awesome... hang in there!   Apr 11 2009, 09:39 PM
jcambo7   :popcorn:   Apr 12 2009, 05:30 PM
r_towle   Its a customers car... Rich   Apr 12 2009, 07:55 PM
McMark   Only if someone buys it before I'm done. :ev...   Apr 13 2009, 10:48 AM
McMark   More work... months later. <_< Engine shel...   Jul 8 2009, 07:05 PM
greenie   More work... months later. <_< Engine she...   Jul 8 2009, 07:58 PM
r_towle   More work... months later. <_< Engine she...   Jul 8 2009, 09:14 PM
markb   Depends, do you know what color it's going to ...   Jul 8 2009, 07:29 PM
pete-stevers   If you think you are not going to mod that compart...   Jul 8 2009, 10:23 PM
ConeDodger   Do it right. We both know that you spend hours pra...   Jul 9 2009, 08:57 AM
McMark   I finally finished the one thing that started off ...   Nov 28 2009, 11:11 PM
JRust   Excellent Mark! Definately nice to spend a lit...   Nov 29 2009, 12:38 AM
McMark   Time to update the ol' progress thread. Some ...   Mar 31 2010, 08:44 PM
kg6dxn   This car going to make it to WCR 2010?   Mar 31 2010, 10:55 PM
McMark   I'm tryin'! If it is, it'll most ...   Mar 31 2010, 11:01 PM
Dr Evil   Fly me out early and I will finish it for you ;)   Apr 1 2010, 12:01 AM
Vacca Rabite   Erics calipers are SO money! Zach   Apr 1 2010, 09:24 AM
RobW   Mark, its good to see you cranking on that thing.....   Apr 1 2010, 09:28 AM
kwales   Hey Mark, I got a dumb question. When you set up...   Apr 1 2010, 10:15 AM
McMark   Can't say that I have... :confused:   Apr 1 2010, 01:53 PM
McMark   Just about finished bleeding the brakes. One more...   Apr 6 2010, 06:46 PM
r_towle   Dont ever touch that rear trunk lid...its art. Ri...   Apr 6 2010, 06:50 PM
McMark   Here's the brake flex video. I had forgotten ...   Apr 7 2010, 10:21 AM
Root_Werks   That is crazy! I haven't ever actually se...   Apr 7 2010, 10:26 AM
RobW   Yikes is right... so that's the "play...   Apr 7 2010, 12:54 PM
bugsy0   So, what's the best repair - scab on a donut s...   Apr 7 2010, 09:35 PM
McMark   Check out this thread. After a bunch of R&D t...   Apr 7 2010, 09:52 PM
McMark   I can't believe I started this thread FOUR yea...   May 28 2012, 09:20 PM
LarryR   VERY cool!! :beer2:   May 28 2012, 09:25 PM
seanery   We need a Like button! :thumbsup:   May 28 2012, 09:28 PM
JimN73   I saw the car Sunday morning. Not only was there ...   May 28 2012, 09:35 PM
ConeDodger   Now to blow up that motor! SVR is having an au...   May 28 2012, 09:50 PM
McMark   Gotta get the registration up to date first. ;)   May 28 2012, 09:54 PM
ConeDodger   Gotta get the registration up to date first. ;) ...   May 28 2012, 10:12 PM
rick 918-S   :beer2:   May 28 2012, 11:26 PM
Lennies914   :Qarl:   May 29 2012, 07:53 AM
jsconst   Nice, was wondering if that thing would ever move ...   May 29 2012, 08:08 AM
r_towle   Mark, I think my car has sat as long as yours...ma...   May 29 2012, 10:34 AM
Dave_Darling   I suppose you could take that blue car I spotted i...   May 29 2012, 11:18 AM
McMark   I suppose you could take that blue car I spotted ...   May 29 2012, 11:24 AM
Dave_Darling   How about YOU take that blue car out to play. :r...   May 29 2012, 06:04 PM
ConeDodger   [quote name='McMark' post='1684092' date='May 29 ...   May 30 2012, 08:40 AM
RoadGlue   Congrats Mark!   May 29 2012, 11:27 AM
McMark   Here are a few details... I installed the 1.7 men...   May 29 2012, 11:42 AM
Marty Yeoman   ...and have the car registered and drivable. :...   May 30 2012, 01:48 PM
McMark   Okay, we took a right turn. :rotfl: The carbs we...   May 30 2012, 11:19 AM
r_towle   If they have been on the shelf...just give this a ...   May 30 2012, 11:32 AM
ChrisNPDrider   Classic :beer2: carb troubles cause the swap to ...   May 30 2012, 01:36 PM
McMark   Different fuel pump is in, fuel pressure set, fire...   May 30 2012, 04:06 PM
ConeDodger   Different fuel pump is in, fuel pressure set, fir...   May 30 2012, 05:26 PM
biosurfer1   Now to get the last few pieces installed, like a ...   May 30 2012, 04:19 PM
Elliot Cannon   Is this the car with the reallly cool mural on the...   May 30 2012, 06:54 PM
brant   I need to buy a pump rebuild kit if you do put the...   May 30 2012, 09:53 PM
McMark   Back window installed. Driver's door outer h...   May 31 2012, 08:45 PM
jsconst   That's awesome, that thing will be a DD in no ...   May 31 2012, 09:28 PM
- Lo-Fi Version Time is now: 26th October 2026 - 10:50 PM
