Speedometer drive cable too short?, successfully tested from both ends |
carl k |
Nov 29 2009, 08:27 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
When I got my '74, the speedometer angle drive was missing and the speedo cable was severely bent. I replaced the speedometer angle drive with a good used unit and put in a brand new Gemo speedometer cable. The speedometer/odometer still doesn't work.
Here's the interesting part, when I disconnect the cable from the speedometer, leave it hanging under the dash, and drive around, I can see and feel the speedometer inner cable turning. Alternately, when I reconnect the cable to the speedo and spin the back end (at the transmission) with a drill, the speedometer and odometer work. It's as if the cable inner is just a tad too short to engage both ends at the same time. Both knurled nuts were tightened all the way. Any experiences like this? Any suggestions? thanks, Carl K. |
VaccaRabite |
Nov 29 2009, 09:08 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I would bet that the speedo/odo is just broken. The Odo being broke is common. The gears are plastic and strip out. I assume that the speedo is similar.
Zach |
Lo-Fi Version | Time is now: 10th June 2024 - 10:35 PM |
