carl k
Nov 29 2009, 08:27 PM
When I got my '74, the speedometer angle drive was missing and the speedo cable was severely bent. I replaced the speedometer angle drive with a good used unit and put in a brand new Gemo speedometer cable. The speedometer/odometer still doesn't work.
Here's the interesting part, when I disconnect the cable from the speedometer, leave it hanging under the dash, and drive around, I can see and feel the speedometer inner cable turning. Alternately, when I reconnect the cable to the speedo and spin the back end (at the transmission) with a drill, the speedometer and odometer work. It's as if the cable inner is just a tad too short to engage both ends at the same time. Both knurled nuts were tightened all the way.
Any experiences like this? Any suggestions?
thanks,
Carl K.
VaccaRabite
Nov 29 2009, 09:08 PM
I would bet that the speedo/odo is just broken. The Odo being broke is common. The gears are plastic and strip out. I assume that the speedo is similar.
Zach
carl k
Nov 30 2009, 09:04 PM
Well I figured out the problem. When I spun the speedo drive cable counterclockwise, the speedo worked. When I drove around with the speedo cable loose and hanging below the dash, it was running clockwise. Turns out the angle drive gearbox I bought from a 914World member was from a 911 (part number 901 318 029 01) and these turn the opposite direction.
Carl K.
r_towle
Nov 30 2009, 09:07 PM
Sorry, but cool to know.
Rich
