Speedometer drive cable too short?, successfully tested from both ends |
carl k |
Nov 29 2009, 08:27 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
When I got my '74, the speedometer angle drive was missing and the speedo cable was severely bent. I replaced the speedometer angle drive with a good used unit and put in a brand new Gemo speedometer cable. The speedometer/odometer still doesn't work.
Here's the interesting part, when I disconnect the cable from the speedometer, leave it hanging under the dash, and drive around, I can see and feel the speedometer inner cable turning. Alternately, when I reconnect the cable to the speedo and spin the back end (at the transmission) with a drill, the speedometer and odometer work. It's as if the cable inner is just a tad too short to engage both ends at the same time. Both knurled nuts were tightened all the way. Any experiences like this? Any suggestions? thanks, Carl K. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:53 AM |
