> European Wiring Harness 1970, Installing Harness- Headlight/Foglight Question
proto31
post Nov 30 2009, 12:01 PM
So, I'm installing my wiring harness, it is a european harness. I'm making this assumption based on one main observation (although there are others that seem to support it). The observation- this is a new harness (4 cylander) (unfortunately I do not have the part number... (IMG:style_emoticons/default/sad.gif) ), there are NO wires going to what would be the side marker lights. Nothing (absolutely certain) has been cut, I can trace all wires and there never were any side marker light wires.
So, my problem is this, there seems to be no wiring coming out of the harness in the passenger compartment area for a fog light switch, there are, however, wires for fog lights up near the front bumper area where they should be. The main wire (white with a yellow stripe) enters the passenger compartment area and goes to a relay, which then jumps directly to the combination relay, from there there are no wires that would normally go to a switch.
I know that there was some different functionality with the Euro fog light operation, but what exactly was the difference? Do the fog lights turn on any time the headlights are on, meaning no need for a fog light switch? Do I need a special head light switch?
Any help would be greatly appreciated!! (IMG:style_emoticons/default/biggrin.gif)
Dan
post Nov 30 2009, 12:25 PM
Resident German
QUOTE(proto31 @ Nov 30 2009, 10:01 AM) *
No. Euro cars had a separate foglight switch if equipped with foglights.
Running your foglights with your lowbeams when it is not foggy (using them as "running" lights) is in fact illegal in germany and will most likely result in a hefty ticket.
There's at leats 3 different types of main wiring looms:
1 - Loom with wires for the foglights and wires for a switch
2 - Loom with wires for foglights but no wires for the switch
3 - Loom with no wires for foglights or switch
It would seem your harness is of the type 2.
I'm afraid you'll have to add the wires and switch yourself.
(IMG:style_emoticons/default/shades.gif) Andy
PS: My '70 /4 was a US spec with no wires for either the foglights or the switch.
- Lo-Fi Version Time is now: 5th July 2025 - 12:14 AM
