| proto31 |
Nov 30 2009, 12:10 PM
Member ![]() ![]() Group: Members Posts: 413 Joined: 2-February 06 From: Costa Mesa, CA. Member No.: 5,515 Region Association: None |
I placed this post in the Garage as well, but maybe it's more appropriate here. So, I'm installing my wiring harness (4 cylinder), it is a european harness. I'm making this assumption based on one main observation (although there are others that seem to support it). The observation- this is a new harness (unfortunately I do not have the part number... sad.gif ), there are NO wires going to what would be the side marker lights. Nothing (absolutely certain) has been cut, I can trace all wires and there never were any side marker light wires.
So, my problem is this, there seems to be no wiring coming out of the harness in the passenger compartment area for a fog light switch, there are, however, wires for fog lights up near the front bumper area where they should be. The main wire (white with a yellow stripe) enters the passenger compartment area and goes to a relay, which then jumps directly to the combination relay, from there there are no wires that would normally go to a switch. I know that there was some different functionality with the Euro fog light operation, but what exactly was the difference? Do the fog lights turn on any time the headlights are on, meaning no need for a fog light switch? Do I need a special head light switch? Any help would be greatly appreciated!! biggrin.gif Dan |
| dr914@autoatlanta.com |
Nov 30 2009, 12:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes certainly no side marker light wires but that is easily overcome by stringing a pigtail harness from the parking light side of the front turn signal the grey with black on the left and the grey with red on the right (pass)
The driving light harness is wired into your euro harness certainly and if you look where the headlight and emergency flasher switches are you will notice the gey with red the black with blue and brown female 90 degree spades that connect to the fog light switch. Everything else is hard wired in for the fog lights but you will notice that they will work with the high beams rather than the low beams like the usa cars I placed this post in the Garage as well, but maybe it's more appropriate here. So, I'm installing my wiring harness (4 cylinder), it is a european harness. I'm making this assumption based on one main observation (although there are others that seem to support it). The observation- this is a new harness (unfortunately I do not have the part number... sad.gif ), there are NO wires going to what would be the side marker lights. Nothing (absolutely certain) has been cut, I can trace all wires and there never were any side marker light wires. So, my problem is this, there seems to be no wiring coming out of the harness in the passenger compartment area for a fog light switch, there are, however, wires for fog lights up near the front bumper area where they should be. The main wire (white with a yellow stripe) enters the passenger compartment area and goes to a relay, which then jumps directly to the combination relay, from there there are no wires that would normally go to a switch. I know that there was some different functionality with the Euro fog light operation, but what exactly was the difference? Do the fog lights turn on any time the headlights are on, meaning no need for a fog light switch? Do I need a special head light switch? Any help would be greatly appreciated!! biggrin.gif Dan |
proto31 1970 European Wiring Harness Nov 30 2009, 12:10 PM
proto31
yes certainly no side marker light wires but that... Nov 30 2009, 12:43 PM
but you will notice that they will work with the ... Nov 30 2009, 02:20 PM
RON S.
but you will notice that they will work with the... Mar 21 2011, 11:19 AM
SirAndy probably due to different lighting laws.
That Sir,... Mar 21 2011, 02:06 PM
Jasfsmith Interesting. My Swiss car #1113 has driving lights... Mar 22 2011, 07:23 AM
SirAndy I can flash them when in low beam as well.
If yo... Mar 23 2011, 03:18 PM
Jasfsmith
If y... Mar 24 2011, 07:33 AM
ArtechnikA
If y... Mar 24 2011, 06:12 PM
SirAndy He's not talking about fog lights, he's ta... Mar 24 2011, 08:30 PM
ArtechnikA
He's not talking about fog lights, he's t... Mar 25 2011, 04:36 AM
MDG
These are (very) high-intensity clear-lens supple... Mar 25 2011, 02:07 PM
ArtechnikA
These? I bought these Euro lights off Gerold last... Mar 25 2011, 02:16 PM
MDG
These? I bought these Euro lights off Gerold las... Mar 25 2011, 03:26 PM
Cap'n Krusty A question for Andy. If there were not 914 drivin... Mar 24 2011, 05:56 PM
RON S.
That Sir... Mar 26 2011, 04:36 PM
RON S.
[quote name='SirAndy' post='1448734' date='Mar 24... Mar 26 2011, 05:01 PM
ArtechnikA
Here's the pics you are asking for of... Mar 26 2011, 05:15 PM
RON S.
Here's the pics you are asking for o... Mar 26 2011, 06:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:56 AM |
