jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,210 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
I bought an Optima Yellow Top about a year ago. It was fairly cheap and still works well. I have been fine tuning my stereo system, wich has a totall of about 700 watts at peak performance. My headlights are still dimming on the higher volume. I have capacitorrs installed next to each amp, but the battery is just not big enough.
My yellow top is rated at 870 amps. The kinetik is rated at 1900 amps. My plan was to install the kinetik hc1800 to replace the yellow top, it is the same size and weighs 54lbs, a little bit heavier than the optima. (not much) Then I was going to replace both capacitors with an hc800 mounted next to the amps in the trunk. (IMG:style_emoticons/default/happy11.gif) Anybody have experience with 2 battery setup in a 914?? the site http://www.kinetikaudio.com/2009/default.asp |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
As I said before, one of the vendors here has 75 and 90 amp stock fit alternators:
http://www.914world.com/bbs2/index.php?sho...;hl=alternators |
jsayre914 |
As I said before, one of the vendors here has 75 and 90 amp stock fit alternators: http://www.914world.com/bbs2/index.php?sho...;hl=alternators pm sent (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 1st August 2025 - 03:41 PM |
