| nycchef |
Nov 30 2009, 09:16 PM
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
got 90% of the rust off my front nsuspension using a grin dong wheel and wire brush. can't get those hard to reach spots like corners, seams and such. used a half a dozen dremel bits. anyone know a good method. i can't get to a bead blaster right now and would like to finish.
| VaccaRabite |
Dec 1 2009, 05:14 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I am interested to hear more about using your "grin dong" to remove rust. I know I don't use mine that way, but maybe I'm just not brave enough to experiment.
Zach |
| nycchef |
Dec 2 2009, 07:29 AM
I am interested to hear more about using your "grin dong" to remove rust. I know I don't use mine that way, but maybe I'm just not brave enough to experiment. Zach it's hard to explain. suffice to say keeping the grin on it is the hard part, if it starts to frown, it won't remove the rust. well.. i think we've run that joke into the ground, don't want the admins to take offense and delete me. now can we get back to the f#@^ng paint |
nycchef rust removal Nov 30 2009, 09:16 PM
McMark Go get a gallon of muriatic acid and a plastic con... Dec 1 2009, 01:14 PM
r_towle If you have air...get a tool called a spot blaster... Dec 1 2009, 02:36 PM
Cevan
If you have air...get a tool called a spot blaste... Dec 1 2009, 02:54 PM
nycchef
If you have air...get a tool called a spot blaste... Dec 1 2009, 02:57 PM
rjames
I am interested to hear more about using your ... Dec 1 2009, 06:27 PM
Greg44
I am interested to hear more about using your ... Dec 2 2009, 07:38 AM
nycchef
[quote name='nycchef' post='1245307' date='Dec 2 ... Dec 2 2009, 07:43 AM
Greg44
[quote name='nycchef' post='1245307' date='Dec 2... Dec 2 2009, 08:43 AM
nycchef
finally a serious participant. have you used eith... Dec 2 2009, 09:49 AM
kwales If yer going to acid dip, I'd buy a box of bak... Dec 2 2009, 10:06 AM
warrenoliver How about a needle scaler? Never used one but I t... Dec 2 2009, 10:08 AM
nycchef
How about a needle scaler? Never used one but I ... Dec 2 2009, 10:29 AM
Gint [quote name='warrenoliver' post='1245367' date='De... Dec 3 2009, 09:24 AM
Dr Evil Try harbor freight for a needle scaler. They are b... Dec 2 2009, 12:04 PM
charliew You can put a clear coat over the rubber under coa... Dec 2 2009, 01:16 PM
Dr Evil Regarding muriatic acid (found at your local pool ... Dec 2 2009, 02:37 PM
nycchef
Regarding muriatic acid (found at your local pool... Dec 3 2009, 07:26 AM
9146986 Go to Home Depot and get "Must For Rust... Dec 3 2009, 07:56 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:15 PM |
