| nycchef |
Nov 30 2009, 09:16 PM
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
got 90% of the rust off my front nsuspension using a grin dong wheel and wire brush. can't get those hard to reach spots like corners, seams and such. used a half a dozen dremel bits. anyone know a good method. i can't get to a bead blaster right now and would like to finish.
| Dr Evil |
Dec 2 2009, 02:37 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Regarding muriatic acid (found at your local pool store), which is HCl, I would recommend phosphoric acid instead. It is less of a PITA to work with and turns the rust in to a sturdy black oxide instead. HCl eats away at the good steel as well. H2PO4 does not do as bad. If you want to know where to get the phosphoric acid, it is the key ingredient in most all rust converters; Ospho (a favorite), Naval jelly, Rust-mort, etc. I used Ospho on the outside of the cutter I was on in the Coast Guard. It proved itself in that environment.
| nycchef |
Dec 3 2009, 07:26 AM
Regarding muriatic acid (found at your local pool store), which is HCl, I would recommend phosphoric acid instead. It is less of a PITA to work with and turns the rust in to a sturdy black oxide instead. HCl eats away at the good steel as well. H2PO4 does not do as bad. If you want to know where to get the phosphoric acid, it is the key ingredient in most all rust converters; Ospho (a favorite), Naval jelly, Rust-mort, etc. I used Ospho on the outside of the cutter I was on in the Coast Guard. It proved itself in that environment. thanks guys, i think i'm gonna stay away from the acids. put in the time and hand sand then use a rust converter, it's only on the inside mounts of the stabalizer bar, not visable really, just don't want to but it back with any rust if possible. hey doc, you ever coming up to the big city? leo is supposed to bring the brood in to the restaurant soon, you and noel can crash here. no real car work , just food and drink |
nycchef rust removal Nov 30 2009, 09:16 PM
McMark Go get a gallon of muriatic acid and a plastic con... Dec 1 2009, 01:14 PM
r_towle If you have air...get a tool called a spot blaster... Dec 1 2009, 02:36 PM
Cevan
If you have air...get a tool called a spot blaste... Dec 1 2009, 02:54 PM
nycchef
If you have air...get a tool called a spot blaste... Dec 1 2009, 02:57 PM
Vacca Rabite I am interested to hear more about using your ... Dec 1 2009, 05:14 PM
rjames
I am interested to hear more about using your ... Dec 1 2009, 06:27 PM
nycchef
I am interested to hear more about using your ... Dec 2 2009, 07:29 AM
Greg44
I am interested to hear more about using your ... Dec 2 2009, 07:38 AM
nycchef
[quote name='nycchef' post='1245307' date='Dec 2 ... Dec 2 2009, 07:43 AM
Greg44
[quote name='nycchef' post='1245307' date='Dec 2... Dec 2 2009, 08:43 AM
nycchef
finally a serious participant. have you used eith... Dec 2 2009, 09:49 AM
kwales If yer going to acid dip, I'd buy a box of bak... Dec 2 2009, 10:06 AM
warrenoliver How about a needle scaler? Never used one but I t... Dec 2 2009, 10:08 AM
nycchef
How about a needle scaler? Never used one but I ... Dec 2 2009, 10:29 AM
Gint [quote name='warrenoliver' post='1245367' date='De... Dec 3 2009, 09:24 AM
Dr Evil Try harbor freight for a needle scaler. They are b... Dec 2 2009, 12:04 PM
charliew You can put a clear coat over the rubber under coa... Dec 2 2009, 01:16 PM
9146986 Go to Home Depot and get "Must For Rust... Dec 3 2009, 07:56 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:59 PM |
