914 v8 conversion with pantera transaxle by ZF |
Chris Hamilton |
Dec 7 2009, 03:59 PM
Senior Member Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
This is the project that I've pieced together and really really want to build, but I already have a 4-cylinder car 914 and a 912 I'm working on, so there is simply no room or budget to build this beast. If I don't get any offers I'm going to build this thing and drive it myself, but it makes sense to put this out here to see if someone with more time and space can build this.
This kit is most of the parts you need to make a very powerful and fun 914 v8 without having to deal with weak and poorly shifting Porsche transmissions. The ZF 5DS-25 transmission was used in the DeTomaso Pantera, the Mongusta, the Maserati Bora, the BMW M1, and upside-down in the Ford GT-40. This is a very strong transmission ( good for 500-1000hp ), and I feel is a much better choice in a 914 than a Porsche 915/930 and G50 transmissions. It was designed to be used in a Mid-Engine car with an American V8. It does not require any clunky cable shifters or rare custom clutch components. This kit includes: -ZF 5DS-25-2 Gearbox from a DeTomaso Pantera This transmission was rebuilt in 2005 by Pantera Performance in Colorado and has only been driven a few thousand miles since. This transmission is in excellent condition. Transmission includes rebuild receipt with list of parts replaced. Transmission also includes gear ratio chart. -Bellhousing adapter by Kennedy Engineering for Pantera gearbox with smallblock Chevy engine. -914 Speedomter calibrated for 275/50R15 tires. -Speedometer cable for 914 speedometer and pantera gearbox -Hydraulic clutch steel braided cable -New McLeod hydraulic throwout bearing -McLeod single plate metallic clutch and pressure plate -McLeod Dual disc clutch/pressure plate/ flywheel for smallblock chevy -Wilwood clutch pedal with master cylinder for hydraulic clutch -Shifter and shift linkage for 914 with pantera gearbox with Momo shift knob -Smallblock chevy motor mount for 914-4 -Pantera transmission mount -V8 tachometer from Autometer -Mechanical water temp gauge and oil pressure gauge -Aluminum SC Front axle beam -Porsche turbo 930 front struts -Brand new replacement bilstein strut inserts for 930 struts -19mm 914 master cylinder -Custom reinforced 914 trailing arms. Trailing arms include needle bearing pivots from elephant racing, 911 rear brakes with calipers and drilled rotors. Flanges are 5-lug with long wheel studs and have adapters for 993/996 CV joints. -993/996 CV joints axles with adapters for Pantera gearbox -Ron Davis racing / Renegade racing radiator with thermally controlled electric fans. -Moroso fill tank -Meziere WP336 electric water pump I am asking $11500 for this kit. You can contact me at chris@hamiltonracing.net Pictures: (IMG:http://www.914world.com/bbs2/uploads_offsite/hamiltonracing.net-5687-1288840567.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/hamiltonracing.net-5687-1288840567.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/hamiltonracing.net-5687-1288840568.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/hamiltonracing.net-5687-1288840568.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/hamiltonracing.net-5687-1288840568.5.jpg) |
charliew |
Dec 7 2009, 05:54 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
I drove my friends 75 pantera in 75 or 76, he still has it. I didn't think it shifted any better than a 915 in the porsche. He has another pantera that needs a tranny. If you ever want to separate the tranny he might be interested. PM me.
Charlie |
Lo-Fi Version | Time is now: 10th June 2024 - 07:05 AM |
