> -6 Points replacement opinions -
Scott S
post Dec 7 2009, 01:35 PM
Small Member
Hi All –
I am looking for some opinions on drop in points replacements for a -6. I am running an MSD 6A, will also be using their coil. I spoke to them on the phone just now and they simply say normal points or any points replacement will work fine – they would not give any reccomendations.
I am using the good old fashioned $60.00 comp-u-fire in the -4 and it has never let me down – but it has always made me a bit nervous based on some previous threads. I am a huge believer in how important a good/cohesive ignition is to a motor. Any opinions are greatly appreciated.
As a side note, I would prefer something without an external “box” if possible. Already hiding the MSD box and tach adapter…
jt914-6
post Dec 7 2009, 04:54 PM
QUOTE(Scott Schroeder @ Dec 7 2009, 01:35 PM) *
That leaves out the Crain...It has an external "box".....
elmonte
post Dec 7 2009, 06:34 PM
QUOTE(jt914-6 @ Dec 7 2009, 02:54 PM) *
They all need a external box, be it a stock CDI or MSD or the Crane box. The Crane optical trigger will work with all of them.
Cheers
brant
post Dec 7 2009, 10:36 PM
QUOTE(elmonte @ Dec 7 2009, 05:34 PM) *
Cheers
I believe scott said he has already accepted the fact that the MSD needs 1 box, and that he intends to hide it.....
as far as signal pick ups go the pertronix does not need an additional box... it is fully hidden within the distributor
thus the only answers to his search are:
... points
or... (IMG:style_emoticons/default/cool.gif) pertronix
I too was leary of the pertronix after using an allison optical system for 15 years (allison sold the design to crane)
however after 6 years of full out racing with a pertronix, I am no longer concerned with their quality. You can NOT leave the ignition key on for over 10 seconds with the motor not running... otherwise there are few draw backs to the pertronix. And in full racing scenario, I chose the pertronix over the crane based on weight.
Scott Schroeder   -6 Points replacement opinions -   Dec 7 2009, 01:35 PM
elmonte   I've been using the Crane optical trigger for ...   Dec 7 2009, 02:07 PM
ClayPerrine   I have a pertronix for my six. Been in since I pu...   Dec 7 2009, 02:49 PM
brant   Scott, go pertronix I've been running it for...   Dec 7 2009, 04:21 PM
jt914-6   As a side note, I would prefer something without ...   Dec 7 2009, 04:54 PM
elmonte   As a side note, I would prefer something without...   Dec 7 2009, 06:34 PM
brant   [quote name='jt914-6' post='1247359' date='D...   Dec 7 2009, 10:36 PM
jt914-6   [quote name='jt914-6' post='1247359' date='D...   Dec 8 2009, 04:57 AM
Mark Henry   If the MSD is just using points as a trigger and t...   Dec 7 2009, 07:32 PM
elmonte   If the MSD is just using points as a trigger and ...   Dec 7 2009, 07:47 PM
type2man   I installed a pertronix upgrade on my 6 and it wor...   Dec 7 2009, 09:09 PM
ahdoman   If you go Petronix try to use the version II. Acco...   Dec 7 2009, 11:24 PM
ericread   If you go Petronix try to use the version II. Acc...   Dec 8 2009, 03:39 PM
elmonte   Not trying to sell the Crane by any means, just se...   Dec 8 2009, 12:00 AM
brant   Not trying to sell the Crane by any means, just s...   Dec 8 2009, 12:18 PM
sww914   My Pertronix has been issue free for 9 years, the ...   Dec 8 2009, 02:44 AM
ClayPerrine   Both of our 914s have pertronix. Mine is used to ...   Dec 8 2009, 07:40 AM
mskala   ... and you get point bounce at high RPM ranges....   Dec 8 2009, 07:18 PM
elmonte   Here are the instructions for the installation of ...   Dec 8 2009, 03:17 PM
Scott Schroeder   Thanks a million all. I am definitely going the pe...   Dec 8 2009, 04:11 PM
jt914-6   I was wrong in my earlier post about the Crain hav...   Dec 8 2009, 08:10 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:29 AM
