gaining HP with an air filter, is it true? |
tradisrad |
Dec 10 2009, 08:38 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I was browsing the AA catalog and came across the MSDS high flow cone air filter (catalog page 28). The ad claims that one can gain upto 10 more HP using this air filter. Is this true? Has anyone else used one of these?
BTW my engine is a 2056, stock FI with Raby's 9550 cam and tuned MPS. HPH sells a bored throttle body and claims HP gain with the TB. True? |
charliew |
Dec 10 2009, 12:14 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
If you can use a air filter that has a element that has smaller holes in the material it will filter better. If that surface area is larger than the prior filter so that it will flow more air, it's gotta be better. More air is always going to give more power. As in most high performance it is the sum of all the parts that makes a good result.
underthetire |
Dec 10 2009, 12:16 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
If you can use a air filter that has a element that has smaller holes in the material it will filter better. If that surface area is larger than the prior filter so that it will flow more air, it's gotta be better. More air is always going to give more power. As in most high performance it is the sum of all the parts that makes a good result. Um, no. Only if you can add extra fuel for the extra air. Otherwise you just lean out. |
orange914 |
Dec 11 2009, 12:43 AM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
If you can use a air filter that has a element that has smaller holes in the material it will filter better. If that surface area is larger than the prior filter so that it will flow more air, it's gotta be better. More air is always going to give more power. As in most high performance it is the sum of all the parts that makes a good result. Um, no. Only if you can add extra fuel for the extra air. Otherwise you just lean out. he's tuned MPS for more fuel so hopefully it'll be richened enough. (IMG:style_emoticons/default/idea.gif) allen "retrofit" (R.I.P.) claimed the top end improved with the cone set up he had. we also can feel a slight top end increase with our home set up. it routes behind the drivers seat up high to get the colder air. it's no science that top end gets choked on o.e. air box's. look at the 2.0 air box's restrictive "pee shooter" intake tube sucking hot air off the top of the motor. i suppose there must be a quality cone filter out there to use, maybe an o.e. ford truck cone couldbe used (IMG:style_emoticons/default/confused24.gif) . |
Lo-Fi Version | Time is now: 12th June 2024 - 12:38 AM |
