> Distributor Question, vacuum-advance VS. centrifugal-advance
steveherman
post Dec 13 2009, 09:30 AM
Looking at the Hot-Spark.com page.
A parts place here is a distributor of their products.
He stopped selling the Pertronix and all other electronic ignition kits... EXCEPT THE HOT-SPARK.
He had a batch of bad Pertronix and the manufacturer would not do anything warranty wise. So he moved on to these.
In three years has had one bad one and the warranty service he said was fantastic.
So i am trying to decide whick one to get...
The vacuum-advance or centrifugal-advance?
Pros and cons of each?
Dr. Roger
post Dec 13 2009, 06:33 PM
A bat out of hell.
Ummm, are you buying an entire distributor or just the ignition spark trigger mechanism.
If it's just the trigger, then you are not making the decision to go either mechanical or vacuum. That Hall Effect switch goes inside your stock distributor and the stock distributor will continue to advance and retard as it did from the factory.
EDIT: Whoops, now I see at the lower area of the page, the distributors. In that case just match the specs of a stock 914 dizzy to one of these. the .009 dizzy's curve specs differ from a stock injected 914 if I remember correctly.
- Lo-Fi Version Time is now: 11th July 2025 - 02:02 PM
