kenshapiro2002 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,444 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region ![]() |
I'm going to eliminate the glove box and the radio. My first thought is to get a flat piece of thin steel (like Porsche used behind the center piece of the dash) that extends from the steering wheel all the way over to the right side where the face ends, and cover that entire piece with the basket weave vinyl. Is that a decent way to execute this? If so, is it correct that it will "sandwich" between the dash top and the knee cap piece, as well as being glued? If so, can i slide it under the dash top or does it need to be removed?
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,249 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
With the bottom dash removed, these pieces are easily installed using double-sided tape to hold the metal to the dash. Not sure how to attach the metal plate over the radio and glovebox holes.
Why no glovebox? I would assume the radio will go somewhere else or replaced by an iPod. |
kenshapiro2002 |
Might eliminate the glovebox just for "cleanliness". I thought about an iPod, but might just go with no tunes...just the engine sounds. How does the ventilation control unit come out?
With the bottom dash removed, these pieces are easily installed using double-sided tape to hold the metal to the dash. Not sure how to attach the metal plate over the radio and glovebox holes. Why no glovebox? I would assume the radio will go somewhere else or replaced by an iPod. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,318 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Lo-Fi Version | Time is now: 22nd September 2025 - 09:15 PM |
