> Hi pressure to low pressure fuel pump conversion, changing to carbs
brandomc
post Dec 15 2009, 12:53 PM
Hey everyone, i was wondering what will be required for me to switch to a low pressure fuel pump for carbs. Do i plug off the return line or do i still use it somehow? Anyone have any specific examples of what they did with all of the extra lines after removing their fuel injection system? Thanks
ME733
post Dec 16 2009, 08:41 AM
(IMG:style_emoticons/default/popcorn[1].gif) ...Lots of ideas in this post Brandomc. here are a few more...1. You will need a low pressure fuel pump, one that is NOT for a fuel injection system. 2. you will need a LOW PRESSURE fuel pressure regulator, and a way to test fuel pressure. fuel pressure should be set at 3.5 psi. 3. you will need a good (metal cannister) fuel filter. 4. you should ensure the fuel pump is "soft" mounted w/ rubber soft mounts. you will need a ground wire to the pump body. the "hot" wire should have a fuse. 5. there are many places you can mount the fuel pump, but THE ENGINE BAY should not be one of them. 6. I cannot suggest strongly enough to run NEW FUEL LINES for the entire system. (the fuel lines are about 35 years old) 7. NOW is a good time to pull the gas tank, and clean it out, especially the fuel strainer/screen filter. You will need to plug off the small line,(inlet fitting) which is/was the fuel injection return line. 8. you will probably find that 5/16 '' fuel line,...( or 8 mm) fits the carburator fittings best. 9, use s.s.hose clamps. 10. install a new metal fuel line through the chassis. finally, If you will do all of this at one time you can eliminate a "fire hassard" as a cause for concern for quite some time. routine maintenance checks are necessary for any fuel system. murray (IMG:style_emoticons/default/popcorn[1].gif)
Cevan
post Dec 16 2009, 12:32 PM
QUOTE(ME733 @ Dec 16 2009, 09:41 AM) *
Is there any reason you can't use the stock fuel filter?
- Lo-Fi Version Time is now: 1st August 2025 - 08:28 AM
