| x98boardwell |
Dec 16 2009, 12:07 PM
Member ![]() ![]() Group: Members Posts: 62 Joined: 14-October 09 From: Central Valley, CA Member No.: 10,935 Region Association: None |
Should the new engine shroud seal that installs in the channels in the firewall be facing down or up?
Also, do we just push in with screwdriver or slide in from the side? Thanks, Bryan |
| McMark |
Dec 16 2009, 03:33 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
QUOTE are you referring to the seals that touch the perimeter of the engine tin? Yes QUOTE Is the firewall you are referring to located just behind the driver/passenger wall? It is the driver/passenger wall. QUOTE The seals at the front (in relationship to the car) and sides are the same part number, the seal at the rear is NLA as far as I recall and different profile than the front and sides. Mikey914 makes replacements. |
x98boardwell How to install engine seal.. facing up or down Dec 16 2009, 12:07 PM
McMark Facing down, and use a screwdriver. They will not... Dec 16 2009, 01:21 PM
x98boardwell McMark,
Thanks, much appreciated. Just like the ... Dec 16 2009, 02:31 PM
type47 This question has me thinkin" (dangerous, I k... Dec 16 2009, 02:43 PM
r_towle slide :rotfl:
that will never happen.
screw driv... Dec 16 2009, 09:00 PM
scotty b
slide :rotfl:
screw dri... Dec 16 2009, 09:11 PM
x98boardwell Seals done.... screwdriver worked... thanks for th... Dec 16 2009, 09:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 04:17 PM |
