Full Version: How to install engine seal.. facing up or down
x98boardwell
Should the new engine shroud seal that installs in the channels in the firewall be facing down or up?
Also, do we just push in with screwdriver or slide in from the side?
Thanks,
Bryan
McMark
Facing down, and use a screwdriver. They will not slide in.
x98boardwell
McMark,
Thanks, much appreciated. Just like the my 930 but wasn't sure.
Bryan
type47
This question has me thinkin" (dangerous, I know) but in the desire to be helpful (dangerous, I know), are you referring to the seals that touch the perimeter of the engine tin? Is the firewall you are referring to located just behind the driver/passenger wall? The seals at the front (in relationship to the car) and sides are the same part number, the seal at the rear is NLA as far as I recall and different profile than the front and sides.
McMark
Yes
It is the driver/passenger wall.
Mikey914 makes replacements.
r_towle
that will never happen.
screw driver...
Rich
scotty b
QUOTE(r_towle @ Dec 16 2009, 07:00 PM) *
screw driver...
Rich
It's Electric..........boogie, oogie, oogie.
x98boardwell
Seals done.... screwdriver worked... thanks for the help. My rear seal (the one that Mikey914 makes) was not bad and did not need replacing. The others were hard and brittle.
Bryan
