| x98boardwell |
Dec 16 2009, 12:07 PM
Member ![]() ![]() Group: Members Posts: 62 Joined: 14-October 09 From: Central Valley, CA Member No.: 10,935 Region Association: None |
Should the new engine shroud seal that installs in the channels in the firewall be facing down or up?
Also, do we just push in with screwdriver or slide in from the side? Thanks, Bryan |
| McMark |
Dec 16 2009, 01:21 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Facing down, and use a screwdriver. They will not slide in.
| x98boardwell |
Dec 16 2009, 02:31 PM
McMark,
Thanks, much appreciated. Just like the my 930 but wasn't sure. Bryan |
| type47 |
Dec 16 2009, 02:43 PM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
This question has me thinkin" (dangerous, I know) but in the desire to be helpful (dangerous, I know), are you referring to the seals that touch the perimeter of the engine tin? Is the firewall you are referring to located just behind the driver/passenger wall? The seals at the front (in relationship to the car) and sides are the same part number, the seal at the rear is NLA as far as I recall and different profile than the front and sides.
| McMark |
Dec 16 2009, 03:33 PM
QUOTE are you referring to the seals that touch the perimeter of the engine tin? Yes QUOTE Is the firewall you are referring to located just behind the driver/passenger wall? It is the driver/passenger wall. QUOTE The seals at the front (in relationship to the car) and sides are the same part number, the seal at the rear is NLA as far as I recall and different profile than the front and sides. Mikey914 makes replacements. |
| r_towle |
Dec 16 2009, 09:00 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
| scotty b |
Dec 16 2009, 09:11 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
It's Electric..........boogie, oogie, oogie. |
| x98boardwell |
Dec 16 2009, 09:59 PM
Seals done.... screwdriver worked... thanks for the help. My rear seal (the one that Mikey914 makes) was not bad and did not need replacing. The others were hard and brittle.
Bryan |
Lo-Fi Version | Time is now: 29th April 2026 - 02:10 PM |
