> High Output Electrical System, I know you guys are laughing at me
jsayre914
post Dec 14 2009, 04:23 PM
Speed Up !!!
I have 2 great hobbys, Porsche 914 and Car Stereo Sound.
I might not be faster than you guys, but I will have a very unique 914. I pulled all the stereo stuff out of my car, and I am starting all over. I just recieved my Kinetik batteries today.
I got a HC1800 to replace my optima, the 1800 is rated at 1900 Amps. I also purchased a HC800 rated at 950 amps. I just found a upgrade 75amp alternator and a guy who will wind it to 120amp output to drop in place of the 55amp unit. I am going to be High Voltage!
The totall draw on my stereo install will be about 120 amps at peak. I am keeping my amplifiers but building a different cabinet for the rear trunk. It will house both amps and the 800 power cell. I am ditching both capacitors that were in the trunk. The wiring will be upgraded from the alternator (Jeff Bowlsby) and I will run "0" guage from the batterys to hook togeather + to + and - to -. I will also add a few more heavy grounds from each battery to chasis and from chasis to engine. Yes there will be multiple inline fuses on the positive leads. (saftey first)
I will update this thread with pics and progress as i go.
(any comments) (IMG:style_emoticons/default/popcorn[1].gif)
jhadler
post Dec 16 2009, 05:31 PM
Long term tinkerer...
Looking at the numbers, it would appear that at steady state, you're pulling 85 A. Now, a 120 A alternator can push that much current. But at what RPM? Can a 120 A alternator push 85+ A at idle speeds?
-Josh2
jsayre914   High Output Electrical System   Dec 14 2009, 04:23 PM
jhadler   Not that big car stereos are my cup o' tea... ...   Dec 14 2009, 04:34 PM
markb   I have a question. Being an old guy, I have to ask...   Dec 14 2009, 04:35 PM
Scott Schroeder   I have a question. Being an old guy, I have to as...   Dec 14 2009, 06:22 PM
markb   I have a question. Being an old guy, I have to a...   Dec 14 2009, 06:32 PM
SLITS   Rock On Sparky ..................   Dec 14 2009, 05:35 PM
SirAndy   RE: High Output Electrical System   Dec 14 2009, 06:17 PM
SirAndy   Same here, permanent damage to the ear drums and a...   Dec 14 2009, 06:31 PM
Scott Schroeder   Same here, permanent damage to the ear drums and ...   Dec 14 2009, 06:36 PM
jsayre914   Thanks for the concern guys. :) I really do feel t...   Dec 14 2009, 06:35 PM
Scott Schroeder   Thanks for the concern guys. :) I really do feel ...   Dec 14 2009, 06:39 PM
SirAndy   I am fuched.... but I had a great time!!...   Dec 14 2009, 06:42 PM
kg6dxn   Having been an IASCA judge for many years... That...   Dec 14 2009, 06:37 PM
Mark Henry   I have 400 watts in my bus and I still can't h...   Dec 14 2009, 06:39 PM
kg6dxn   I have 400 watts in my bus and I still can't ...   Dec 14 2009, 06:52 PM
Mark Henry   I have 400 watts in my bus and I still can't...   Dec 14 2009, 07:14 PM
SLITS   Rock music, loud industrial equipment, hunting and...   Dec 14 2009, 06:51 PM
iamchappy   I think high power systems sound much crisper and ...   Dec 14 2009, 07:05 PM
SirAndy   I lost some of my hearing at a Plasmatics concert...   Dec 14 2009, 07:20 PM
Spoke   ROCK ON, DUDE! You'll have a kick ass ste...   Dec 14 2009, 08:05 PM
r_towle   your system will draw 120 amps. Your alternator wi...   Dec 14 2009, 08:51 PM
SGB   your system will draw 120 amps. Your alternator w...   Dec 14 2009, 10:56 PM
orange914   i used to have a bumper sticker on my olds 442 tha...   Dec 14 2009, 09:14 PM
underthetire   i used to have a bumper sticker on my olds 442 th...   Dec 16 2009, 05:24 PM
Spoke   I believe to correctly specify the electrical syst...   Dec 15 2009, 07:55 AM
SirAndy   RMS = Peak /(2 x sqrt(2)) = 120/(2 x sqrt(2)) ~ 4...   Dec 15 2009, 11:48 AM
zymurgist   sqrt(100) Anyone see anything wrong with that? ...   Dec 15 2009, 12:48 PM
jsayre914   I dont believe i will ever be running at constant ...   Dec 15 2009, 08:32 AM
flipb   Worst case, shut off the sound system for the last...   Dec 15 2009, 08:35 AM
iamchappy   I have one of the amps mounted under the dash ster...   Dec 15 2009, 11:41 AM
Dr Evil   it = 10 :rotfl: After all this, will the 1.8 be a...   Dec 15 2009, 12:40 PM
SirAndy   After all this, will the 1.8 be a 50hp output mon...   Dec 15 2009, 12:46 PM
zymurgist   After all this, will the 1.8 be a 50hp output mo...   Dec 15 2009, 12:49 PM
Spoke   He can now use the stereo as a emergency brake...   Dec 16 2009, 05:17 PM
jhadler   Looking at the numbers, it would appear that at st...   Dec 16 2009, 05:31 PM
jsayre914   i will let you guys know, once i get her installed...   Dec 18 2009, 10:30 PM
Krank   what?   Dec 18 2009, 10:47 PM
jsayre914   what? :confused: Did you have a question??   Dec 18 2009, 11:17 PM
Spoke   [quote name='Krank' post='1252604' date='Dec 18 2...   Dec 18 2009, 11:40 PM
jsayre914   figured i would post the pics of my swap. Basicall...   Jan 12 2010, 09:46 AM
jsayre914   Picture of the old harness and the new harness vs...   Jan 12 2010, 09:48 AM
jsayre914   side by side comparison 55 amp vs 120 amp :chow:   Jan 12 2010, 09:51 AM
jsayre914   Then to get the pullys off it is a little tricky, ...   Jan 12 2010, 09:53 AM
jsayre914   Now that they match, I painted the pulley so it wo...   Jan 12 2010, 10:00 AM
jsayre914   The Bolt was a little tight so had to be adjusted ...   Jan 12 2010, 10:05 AM
jsayre914   The Final result, looks almost stock and fits exac...   Jan 12 2010, 10:07 AM
jsayre914   Now I should have just enough power to listen to m...   Jan 12 2010, 10:09 AM
SirAndy   Any way you could have kept the cooling fins? Woul...   Jan 12 2010, 02:14 PM
detoxcowboy   Any way you could have kept the cooling fins? Wou...   Jan 12 2010, 03:19 PM
Dr Evil   Why are you running two different batteries? One i...   Jan 12 2010, 11:22 PM
- Lo-Fi Version Time is now: 10th June 2026 - 11:49 PM
