> Building a 2056
swood
post Nov 29 2009, 06:36 PM
Just realized I was adding project info to a WTB add....so moving it to the garage.
It hit me today that since I'm using L-Jet heads, I need to add venting for the crankcase. Is the best method to drill and tap for a threaded insert?
I've been reviewing breather boxes too. Not sure which I want. I'll be using cabin heat so if the breather puts out fumes, I'm putting it into the trunk.
For the breather set up, I may need an early oil filler unit with the port on it. Anyone have one handy? I have the '75 LJet unit, can I modify this to work? Or can I use the larger diameter port that is t'd off the filler neck?
Since I'll have to have this machining done, anything else I should do, like relocating the spark plug hole? Is that really a significant upgrade? The valves were re-done, 42x36.
Got Weber 40's coming, 71mm crank/rods, Webcam 86b. Need to swap out the KB pistons with ones for the correct wrist pin ht. Also going to install 8mm rocker studs. maybe longer oil pump studs for the 30mm Shadek.
Need to get the crank polished and rotating assembly balanced. I think in my spare '74 motor lies a fan with all the blades. Need to pull that out too.
I will definitely need to get some of the wiring issues sorted out going from LJet FI to carbs.
swood
post Dec 18 2009, 10:08 AM
Ok, so now I'm looking for a fuel pressure regulator. I'd like to use the fuel return set up, since I have CF's nice fuel lines.
I'd like to get a recommendation on which model to pick up. I was looking at the Mallory 4309 for about $90 + accessories. What do you guys think?
swood   Building a 2056   Nov 29 2009, 06:36 PM
r_towle   Heads, Drill and tap them for a breather fitting. ...   Nov 29 2009, 07:18 PM
swood   OK, cool. sounds straight forward enough. How does...   Nov 29 2009, 07:29 PM
r_towle   fitting gets mounted the same as the pcv valve...a...   Nov 29 2009, 07:34 PM
Gint   If you can drill straight enough, you don't ha...   Nov 29 2009, 08:00 PM
swood   Do I need to add a pcv valve?   Nov 29 2009, 08:12 PM
Racer Chris   Do I need to add a pcv valve? No. I'm prett...   Nov 29 2009, 08:39 PM
swood   Chris, it looks like the inlet is about 3/4" ...   Nov 29 2009, 09:14 PM
swood   Hows this for the vent connection? http://www.mcm...   Nov 29 2009, 09:26 PM
jd74914   Hows this for the vent connection? http://www.mc...   Nov 29 2009, 09:37 PM
swood   Ok, the Home Defect it is... Barbed NPT fitting   Nov 29 2009, 09:44 PM
Racer Chris   I need to add venting for the crankcase. Is the ...   Dec 12 2009, 02:51 AM
swood   I'm pullin the heads to change out the rocker ...   Dec 12 2009, 01:27 PM
swood   X marks the spot? Definitely at an angle away from...   Dec 12 2009, 05:18 PM
Racer Chris   AFAIK all the 914 heads had the boss for the tube....   Dec 12 2009, 07:13 PM
swood   Ok, so now I'm looking for a fuel pressure reg...   Dec 18 2009, 10:08 AM
swood   That was easy. :sawzall:   Jan 2 2010, 07:30 PM
kg6dxn   I use Aeromotive 13301, adjustable from 3-20 psi a...   Jan 2 2010, 08:28 PM
swood   I use Aeromotive 13301, adjustable from 3-20 psi ...   Jan 2 2010, 10:50 PM
KaptKaos   http://www.cbperformance.com/catalog.asp?ProductID...   Jan 2 2010, 10:57 PM
swood   http://www.cbperformance.com/catalog.asp?ProductI...   Jan 2 2010, 11:06 PM
KaptKaos   Return line? Why would you need a return line wit...   Jan 2 2010, 11:12 PM
swood   Keep the fuel circulating and cool. Not necessary,...   Jan 2 2010, 11:15 PM
kwales   Wow, a return line in a low pressure system..... ...   Jan 3 2010, 11:29 AM
swood   So I'm detailing my rockers while watching str...   Feb 13 2010, 04:37 PM
Racer Chris   8 x 1.25 is standard for most 8mm bolts, but the v...   Feb 13 2010, 08:39 PM
swood   That's kinda what I thought. Thanks.   Feb 13 2010, 09:01 PM
Gint   If you run an actual thread cutting tap through th...   Feb 14 2010, 10:32 AM
swood   Yeah, you're probably right. i just need to cl...   Feb 14 2010, 11:06 PM
swood   Got some minor body damage, not too bad, but i can...   May 18 2010, 09:48 PM
swood   Left side looks good. The right side has metal mis...   May 18 2010, 09:49 PM
KaptKaos   And you are??? :lol:   May 19 2010, 01:05 AM
swood   Just a guy looking for a little help... :chair: ...   May 19 2010, 10:45 AM
Aaron Cox   Just a guy looking for a little help... :chair: ...   May 19 2010, 12:24 PM
swood   Just a guy looking for a little help... :chair:...   May 19 2010, 03:29 PM
- Lo-Fi Version Time is now: 12th July 2025 - 03:49 PM
