Impeller bolt? |
Impeller bolt? |
jeffdon |
Dec 21 2009, 03:51 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
OK, I was getting smug with myself for keeping such good track of all my parts. Now i cannot find the bolts that hold the impeller to the hub, not the bolt that holds the hub to the crank. Cannot even recall if there is a spacer that goes in the hub/crank bolt. Where can I find myself the proper parts?
SLITS |
Dec 21 2009, 04:13 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Any hardware store that sells metric fastners. Either flat headed or allen socket head as it depends on what your impeller looks like. If the impeller has a recess for the bolts use allen head.
or CV joint bolts And yes, the bolt that holds the hub to the crank has a washer. Make sure you check the length of the bolts for the impeller to the hub. You don't want them sticking out of the hub on the backside where they will dig into the case. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:36 PM |
