> Any easy ways to install the 3 piece top targa seal?, One part is half way in, and she fully lubed...and NADA
wallys914
post Dec 21 2009, 06:43 PM
In life you don't get what you want, you get what you negoia
I used wd40 to lube up the one side and attempted entry; but failed half way through, the side I was working on just would not budge after I got half stuffed in there....
Any ways to get that seal in with out breaking it? or disfiguring it?
tradisrad
post Dec 21 2009, 08:39 PM
I just did my targa seal. I used windex to lube it. It was not easy to install and took a bit of time. I worked one side at a time and lubed the leading and trailing ends of the rubber/track as I worked it in. Be aware that the track may have been pinched to hold the previous seal and any pinching needs to be straightened before the rubber will slide in.
- Lo-Fi Version Time is now: 9th December 2025 - 06:58 PM
