> Anybody ever used a Kinetik Battery?, I am thinking to replace my optima
jsayre914
post Nov 30 2009, 05:55 PM
Speed Up !!!
I bought an Optima Yellow Top about a year ago. It was fairly cheap and still works well. I have been fine tuning my stereo system, wich has a totall of about 700 watts at peak performance. My headlights are still dimming on the higher volume. I have capacitorrs installed next to each amp, but the battery is just not big enough.
My yellow top is rated at 870 amps.
The kinetik is rated at 1900 amps.
My plan was to install the kinetik hc1800 to replace the yellow top, it is the same size and weighs 54lbs, a little bit heavier than the optima. (not much) Then I was going to replace both capacitors with an hc800 mounted next to the amps in the trunk. (IMG:style_emoticons/default/happy11.gif)
Anybody have experience with 2 battery setup in a 914??
the site
http://www.kinetikaudio.com/2009/default.asp
jsayre914
post Dec 22 2009, 08:40 AM
Speed Up !!!
I set the Kinetik in place of the yellow top, WOW. I have not hooked it up yet, still waiting on a few wires, just wanted to check the fit. The rain tray needed a slight modification to close (IMG:style_emoticons/default/rolleyes.gif)
What do you think about placment of the second battery, it is not heavy at all, so I made a tray, and hinged a tray under it for the relay to sit at a 45 angle, that way i dont need to move any wiring.
(IMG:style_emoticons/default/aktion035.gif)
post Dec 22 2009, 11:55 AM
Resident German
QUOTE(jsayre914 @ Dec 22 2009, 06:40 AM) *
What do you think
I think you need to clean that damn engine bay! (IMG:style_emoticons/default/rolleyes.gif)
(IMG:style_emoticons/default/FERG.gif)
- Lo-Fi Version Time is now: 1st August 2025 - 03:41 PM
