> Door lock issues, I have sprayed brake clean
burton73
post Oct 31 2009, 06:29 PM
Senior member, and old dude
My driver’s door has this problem where you can lock it or turn it with the key to the right fine but it does not want to come back to the left clean all the time. The keys work in all the locks and are in good shape. I have tried two different sets the red one and the black. A new set and an original set from the car.
I was on the phone with Eric Shea for something different and he thought because it was sticking to spray brake cleaner in the key slot. I did put the red nosel in deep and gave the lock a lot of cleaning. I know I did a good job as there was a bit of black grease that came out. I did this 3 times. It stills will not work like the right door.
I have to turn it to the right then left a few times to get it to unlock. It seems to lock fine but does not want to unlock at this tumbler. Do you think if I take an extra tumbler from a different lock to a locksmith to match to my key this will work as my pins may be warn or the lock may be screwed.
Any ideas.
Bob
(IMG:style_emoticons/default/headbang.gif)
campbellcj
post Dec 22 2009, 03:29 PM
I can't Re Member
AFAIK graphite is the lube of choice and has always worked for me. Moderate careful application is the key (no pun intended)
burton73   Door lock issues   Oct 31 2009, 06:29 PM
Pat Garvey   My driver’s door has this problem where you can...   Oct 31 2009, 07:17 PM
Phoenix-MN   First make sure the lock tunblers are really clean...   Oct 31 2009, 07:17 PM
markb   You may also need to clean the actual door mechani...   Oct 31 2009, 07:27 PM
kenshapiro2002   Just did mine...took the lock cylinder all the way...   Oct 31 2009, 07:34 PM
Jerry75914   I had the same problem. As several folks have alr...   Oct 31 2009, 08:08 PM
orange914   i'm not clear if you can turn the key both way...   Nov 1 2009, 04:18 PM
burton73   i'm not clear if you can turn the key both wa...   Nov 2 2009, 12:55 PM
burton73   I just had the right handle off today, as the plas...   Oct 31 2009, 08:59 PM
underthetire   I was told to use powdered graphite as a lube, not...   Nov 2 2009, 12:59 PM
kenshapiro2002   [size=7]NO GRAPHITE! :blink: [quote name='u...   Nov 2 2009, 01:41 PM
DBCooper   [size=7]NO GRAPHITE! :blink: [quote name='...   Dec 22 2009, 05:52 AM
underthetire   Geez, you don't need to scream. :hissyfit: :l...   Nov 2 2009, 01:57 PM
jetboy   [size=7]NO GRAPHITE! :blink: [quote name='...   Dec 22 2009, 04:59 AM
campbellcj   AFAIK graphite is the lube of choice and has alway...   Dec 22 2009, 03:29 PM
koozy   works well for me too.   Dec 22 2009, 03:56 PM
Rob-O 1167   I've always used white lithium grease. They w...   Dec 22 2009, 04:36 PM
Drums66   I've always used white lithium grease. They ...   Dec 23 2009, 01:27 PM
sendjonathanmail   Wurth makes a great lube that sprays a similar con...   Dec 22 2009, 05:39 PM
kconway   I've always been told you never use an oil in ...   Dec 22 2009, 07:12 PM
Cap'n Krusty   I know a locksmith who is related to the guy who i...   Dec 22 2009, 07:30 PM
koozy   Tri-Flow is good too. It's basically Teflon an...   Dec 22 2009, 09:22 PM
P.Rocket   :agree: I've used Tri-flo for my whole care...   Dec 22 2009, 09:29 PM
mojorisen914   When I re-did my locks back in November, I used br...   Dec 23 2009, 10:26 AM
- Lo-Fi Version Time is now: 2nd July 2026 - 04:27 AM
