| burton73 |
Oct 31 2009, 06:29 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 4,042 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
My driver’s door has this problem where you can lock it or turn it with the key to the right fine but it does not want to come back to the left clean all the time. The keys work in all the locks and are in good shape. I have tried two different sets the red one and the black. A new set and an original set from the car.
I was on the phone with Eric Shea for something different and he thought because it was sticking to spray brake cleaner in the key slot. I did put the red nosel in deep and gave the lock a lot of cleaning. I know I did a good job as there was a bit of black grease that came out. I did this 3 times. It stills will not work like the right door. I have to turn it to the right then left a few times to get it to unlock. It seems to lock fine but does not want to unlock at this tumbler. Do you think if I take an extra tumbler from a different lock to a locksmith to match to my key this will work as my pins may be warn or the lock may be screwed. Any ideas. Bob (IMG:style_emoticons/default/headbang.gif) |
| kconway |
Dec 22 2009, 07:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I've always been told you never use an oil in lock cylinders as it will attract dirt and gum things up. Dry Graphite is the prefered lubricant for lock cylinders.
burton73 Door lock issues Oct 31 2009, 06:29 PM
Pat Garvey
My driver’s door has this problem where you can... Oct 31 2009, 07:17 PM
Phoenix-MN First make sure the lock tunblers are really clean... Oct 31 2009, 07:17 PM
markb You may also need to clean the actual door mechani... Oct 31 2009, 07:27 PM
kenshapiro2002 Just did mine...took the lock cylinder all the way... Oct 31 2009, 07:34 PM
Jerry75914 I had the same problem. As several folks have alr... Oct 31 2009, 08:08 PM
orange914 i'm not clear if you can turn the key both way... Nov 1 2009, 04:18 PM
burton73
i'm not clear if you can turn the key both wa... Nov 2 2009, 12:55 PM
burton73 I just had the right handle off today, as the plas... Oct 31 2009, 08:59 PM
underthetire I was told to use powdered graphite as a lube, not... Nov 2 2009, 12:59 PM
kenshapiro2002 [size=7]NO GRAPHITE! :blink:
[quote name='u... Nov 2 2009, 01:41 PM
DBCooper
[quote name='... Dec 22 2009, 05:52 AM
underthetire Geez, you don't need to scream. :hissyfit: :l... Nov 2 2009, 01:57 PM
jetboy
[quote name='... Dec 22 2009, 04:59 AM
campbellcj AFAIK graphite is the lube of choice and has alway... Dec 22 2009, 03:29 PM
koozy works well for me too.
Dec 22 2009, 03:56 PM
Rob-O 1167 I've always used white lithium grease. They w... Dec 22 2009, 04:36 PM
Drums66
I've always used white lithium grease. They ... Dec 23 2009, 01:27 PM
sendjonathanmail Wurth makes a great lube that sprays a similar con... Dec 22 2009, 05:39 PM
Cap'n Krusty I know a locksmith who is related to the guy who i... Dec 22 2009, 07:30 PM
koozy Tri-Flow is good too. It's basically Teflon an... Dec 22 2009, 09:22 PM
P.Rocket :agree:
I've used Tri-flo for my whole care... Dec 22 2009, 09:29 PM
mojorisen914 When I re-did my locks back in November, I used br... Dec 23 2009, 10:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd July 2026 - 04:25 AM |
