| bluhun |
Dec 23 2009, 08:11 PM
Member ![]() ![]() Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California |
[font=Arial][size=7]
I'm running the Porterfield R4S street pads front and rear (Boxster calipers and rotors up front, with widened 914 rear calipers and 20 mm vented and cross-drilled rotors), and they squeal like a Banshee! I'm running the anti-squeal shims and we've tried the Wurth anti-squeal treatment, but to no avail. Is there any tried and true cure for this malady or is this just par for the course with carbon-kevlar pads? |
| detoxcowboy |
Dec 23 2009, 11:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
[font=Arial][size=7] I'm running the Porterfield R4S street pads front and rear (Boxster calipers and rotors up front, with widened 914 rear calipers and 20 mm vented and cross-drilled rotors), and they squeal like a Banshee! I'm running the anti-squeal shims and we've tried the Wurth anti-squeal treatment, but to no avail. Is there any tried and true cure for this malady or is this just par for the course with carbon-kevlar pads? I use the same porterfields and get small squeel when very slow stopping only, when they heat up you can feel the grip really improve.. when you need them to really work hard they are there for you. |
bluhun Porterfield R4S Brake Squeal Dec 23 2009, 08:11 PM
Racer Chris I think its common with carbon/kevlar pads. Its ha... Dec 23 2009, 08:21 PM
ArtechnikA
...squeal like a Banshee! I'm running th... Dec 24 2009, 08:16 AM
ConeDodger I have the R4S pads at all four corners of both th... Dec 24 2009, 09:00 AM
tat2dphreak
:agree:
my R4S pads never squeaked, when they we... Dec 24 2009, 09:27 AM
r_towle From my understanding, brake squeal is not from th... Dec 24 2009, 12:43 PM
iamchappy I had some squeal on mine when using solid rotors ... Dec 24 2009, 01:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th March 2026 - 10:05 PM |
