Dominic |
Dominic ![]() ![]() ![]() Group: Members Posts: 993 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California ![]() |
I would love to see the dyno results on this 4-16 BHP gain (IMG:style_emoticons/default/bs.gif)
Maybe he offers free CNC head porting with those battery ground cables (IMG:style_emoticons/default/confused24.gif) Free headers (IMG:style_emoticons/default/confused24.gif) I have been searching for an extra 16 BHP for quite some time and I can't believe it was hiding this whole damn time in my stock battery cables??? (IMG:style_emoticons/default/WTF.gif) http://cgi.ebay.com/ebaymotors/BATTERY-UBE...=item2c5240be04 BATTERY UBERGROUND MOST PORSCHE 911 912 '68-88 MODELS 4-16 BHP gain + Overall Improvements US Made UL Approved 1 KabelMann Uberground Negative cable KM0012 - 12inches overall length Fitment for: Porsche 911 '64-'88 924/944 '77-'96 BMW 316 318i 320i 323 325 328 330 e i is, 520 523 525 528 530 535 540 e i is, M3 M5 M6 model BMW's early and late Mercedes Benz: 190E 260E 300E 500E E320 E420 E430 E500 C220 C230 C280 C320 C36 C43 *Based on above car manufacturer specs this will fit the listed cars HOWEVER, Please measure your stock battery-ground wire Measure your stock battery-ground wire end to end if unsure Fully made In USA 2-ott/Double-Zero Gauge, 12mm thick fine-strand 99.9 pure copper wire Heavy Butyl Rubber casing with anti-moisture inner layer Tin-coated thick-wall copper terminals, corrosion resistant. Triple hex-crimped [at each end= 36 maximum contact areas Weather-protected heat-shrink wrapped connections BIG 2-ott/double-zero [-2x gauge] fine-strand 99.9 pure copper vs typical stock grounds: 4 or 2-gauge blended-alloy wire 4-16HP gain due to less Alternator load and increased ignition spark energy greatly lowered circuits resistance Noticeable overall improvement of electrical functions, driveability, roadworthiness Our KabelMan Uberground works on basic principle Each powered circuit/part has its own [+] supply line from batt thru switching; yet all flowing circuits return through the batt [-] pole/side via 1 lone wire/line which tends to get coagulated w/ electrical noise and resistance. By eliminating almost all the 'traffic' getting back around through the main ground cable better conductivity and efficiency is achieved BHP gains are by less work for alternator, better spark signal from minimal resistance, 'noise'. Increased conductivity= much lowered resistance through vehicle electrical circuits provides less alternator load, more ignition spark energy Alternators consume up to 24 HP while engine running Starter cranks stronger; better starting moments Extended life of alternator, battery, starter, coils, relays, control/computer boxes, other components Wipers, power windows, lighting, stereo radio, etc. work better especially on older classic vehicles Great upgrade to old or new BMW Porsche Mercedes electrical systems |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Another thread on this went around earlier, in case you want to get in on more entertainment.
Lo-Fi Version | Time is now: 1st August 2025 - 06:56 PM |
