solid motor mounts |
southern 914 |
Feb 23 2004, 09:36 PM
Newbie Group: Members Posts: 1 Joined: 23-February 04 From: Tucson Az Member No.: 1,705 |
I have a 914-6 conversion (IMG:style_emoticons/default/rolleyes.gif) But it is about to eat it's second oil pressure sender (IMG:style_emoticons/default/mad.gif) It has been sugested that I put in some rubber mounts that the solid ones pass to much vibration to the sender. If I stay with this setup I should mount the sender to the firewall. Also I have the CIS injection, they tell me this also does not like the vibration but it sure runs strong at the track.
What are ideas you all have - solid or rubber. What does solid mounts really do for you. Haven't seen this thread before. Thanks in advance |
Mike D. |
Feb 24 2004, 06:04 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
another question along this same line....
What if "someone" was to use solid transmision mounts and the rubber engine mounts, any advantages? pros, cons? still no good? -Mike D. |
Lo-Fi Version | Time is now: 16th June 2024 - 08:22 AM |
