solid motor mounts |
southern 914 |
Feb 23 2004, 09:36 PM
Newbie Group: Members Posts: 1 Joined: 23-February 04 From: Tucson Az Member No.: 1,705 |
I have a 914-6 conversion (IMG:style_emoticons/default/rolleyes.gif) But it is about to eat it's second oil pressure sender (IMG:style_emoticons/default/mad.gif) It has been sugested that I put in some rubber mounts that the solid ones pass to much vibration to the sender. If I stay with this setup I should mount the sender to the firewall. Also I have the CIS injection, they tell me this also does not like the vibration but it sure runs strong at the track.
What are ideas you all have - solid or rubber. What does solid mounts really do for you. Haven't seen this thread before. Thanks in advance |
maf914 |
Feb 25 2004, 08:08 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I have read somewhere (?) that solid mounts can lead to cracked/failed tranny mounting ears. Anyone know if there's any truth to that?
Also, I've seen the Weltmeister solid tranny mounts. They appear to be a block of polyurethane with a bolt through it. It looks like they are solid in tension but would flex a bit in compression. Are these considered solid or flexible? Are they any good? Mike |
Lo-Fi Version | Time is now: 16th June 2024 - 03:36 AM |
