Help, car will not start after I removed motor for 1 month |
x98boardwell |
Jan 6 2010, 09:46 AM
Member Group: Members Posts: 62 Joined: 14-October 09 From: Central Valley, CA Member No.: 10,935 Region Association: None |
So, I removed the motor for a tune up. I have listed the things below that I have done so we know but I am fairly confident that it is a fuel related issue. I plan on disconnecting the fuel line today to make sure I am getting fuel but still I am confused. There is not even a sputter or anything. The car is a 1975 2.0 and completely stock with Fuel Injection and ran fantatsic before I pulled the motor.
1) Plugs, Wires, Cap, Rotor, Points, Coil, etc. (I checked and have good spark) 2) Full exhaust Change to old style 2.0 3) Removed air pump, fan pulley housing, injection lines and plugged injector holes 4) Changed out/replaced all vacumn lines 5) Replaced injector gaskets, plenum gaskets, throttle body gaskets, cleaned everything out before re-assembling. 6) New A/C compressor and lines I think that is it. I did replace or repair some old wires in the engine bay that were either hard or cracked or both. Also, all shift linkages, bushings, etc. When I was working on the car I noticed that one of the fuel lines (when it would fall to the ground from where I had it supported) would leak fuel continiously if I didn't raise it up. I also cleaned the motor as well and protected all electrical components with plastic bags to not get wet. When all of the fuel is out of lines could it be that I need to prime the lines? Should I turn the ignition on with the supply line dettached from the car lines until fuel sprays out of that hose? I am just confused as to why there is absolutley no response like the ignition is off, or no fuel. The pump was replaced about 400 miles before I dropped the motor so brand new pump. Any advice? Thanks, Bryan |
Sleepin |
Jan 7 2010, 03:32 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Make sure the fuel lines are not crossed.... I dunno how I know that one! (IMG:style_emoticons/default/huh.gif)
http://www.pelicanparts.com/914/technical_...el_diagrams.htm |
x98boardwell |
Jan 9 2010, 07:02 PM
It runs fantastic. It was the broken wire I found for the switch that fires the injectors on the side of the dist.
High Performance House saved the day and he was great to work with. Thanks for all the help. Bryan |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:14 PM |
