buhs914 |
Not So Newbie ![]() ![]() Group: Members Posts: 331 Joined: 16-June 09 From: Buckeye, AZ Member No.: 10,478 Region Association: Southwest Region ![]() |
Well i took the engine out around 4-5 months ago to clean it up and fix a couple oil leaks. A couple weeks later i ran out of work and money and had been searching for a job since. I recieved a decent amount of money during Christmas and New Years and used most of it to finish my car. I get it all hooked up and about 95% road worthy and it doesn't start. (IMG:style_emoticons/default/headbang.gif) The starter spins and the engine gets gas but it doesn't even seem to try to start. I redid almost 100% of the ignition system about a year ago so most of the parts are newish. I checked the coil for a spark and it has one, but when i get to the cap I only get a spark on 1 out of 4 or sometimes no spark at all. So i checked to see if the points were working properly and noticed that the wire that goes from the points to the condenser was fried. I don't know how that happened because i'm 100% sure everything is hooked up right. I quadruple checked to make sure. Any ideas guys?
P.S. I need this car going before Friday so quick help would me much appreciated. Thanks! |
rnellums |
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,673 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains ![]() |
I'd say it looks like a problem in your dist. maybe the rotor isn't in the correct position when the points open? so it doesn't actually contact the cables. have you tried rotating the distributor around as you turn over the engine?
Lo-Fi Version | Time is now: 3rd September 2025 - 07:02 AM |
