> Welding Saftey around Gasoline?
detoxcowboy
post Jan 12 2010, 11:06 PM
Region Association: Africa
Ignornat questions but..
When welding in the front trunk A.C. hole is it safe not to pull the gas tank? Full tank gas better?
When welding in the engine compartment (shelf below battery where fuel lines have to be disconnected as they pass through that shelf) what do you do with open fuel lines, cap them? wet towel? Engine will be pulled so I could not just leave them connected unitl I finished??
I have no problem smoking around gas just welding is a little hot spark??
J P Stein
post Jan 16 2010, 09:56 AM
Irrelevant old fart
I knew a fella years back that had his face permanently rearranged by a gas tank explosion casued by his welding on it. This is somewhere where I don't screw around with half measures. All the "tricks" to make it safe might work, but you only have to get it wrong once.
I've got enuff explosive/inflammable shittage in my shop that if something ever set it off, half the neighborhood might go up.....and I like my neighbors.
Liquid gasoline has a mass of vapors coming off it......to think otherwise will get you in deep shit.
detoxcowboy   Welding Saftey around Gasoline?   Jan 12 2010, 11:06 PM
messix   BOOM! :welder:   Jan 12 2010, 11:12 PM
detoxcowboy   BOOM! :welder: :DRUNK: :toke: :welder: ...   Jan 12 2010, 11:50 PM
rick 918-S   Pull the tank. It's not that hard. It only tak...   Jan 12 2010, 11:20 PM
messix   throw a big wet towel over the lines and keep them...   Jan 12 2010, 11:53 PM
Scott Schroeder   throw a big wet towel over the lines and keep the...   Jan 13 2010, 10:30 AM
messix   throw a big wet towel over the lines and keep th...   Jan 13 2010, 07:03 PM
detoxcowboy   [quote name='Scott Schroeder' post='1261347' date...   Jan 13 2010, 07:05 PM
Rand   Echo Troy. Simple, no worries. Throw some wet towe...   Jan 13 2010, 12:12 AM
aircooledtechguy   You wanna talk about real freaking out, my dad us...   Jan 13 2010, 10:18 AM
sww914   I've done all the stuff they say to not do and...   Jan 13 2010, 10:36 AM
ericread   There's always the idea of submerging the enti...   Jan 13 2010, 10:42 AM
Dr Evil   I have heard of dry ice being used. Just drop a fe...   Jan 13 2010, 02:26 PM
ME733   :popcorn: ...Lots of mostly good Ideas , have bee...   Jan 14 2010, 08:31 AM
Geezer914   Pull the tank and plug the lines, why take a chanc...   Jan 14 2010, 05:39 PM
Rand   It's not necessary to pull the tank and plug/f...   Jan 14 2010, 08:50 PM
detoxcowboy   It's not necessary to pull the tank and plug/...   Jan 14 2010, 11:16 PM
Rico Suave   JB weld or pull the tank, fill with water...or hav...   Jan 14 2010, 11:50 PM
Racer Chris   JB weld or pull the tank, fill with water...or ha...   Jan 15 2010, 04:39 AM
detoxcowboy   JB weld or pull the tank, fill with water...or ha...   Jan 15 2010, 09:29 AM
rick 918-S   JB weld or pull the tank, fill with water...or h...   Jan 16 2010, 09:28 AM
J P Stein   I knew a fella years back that had his face perman...   Jan 16 2010, 09:56 AM
Rico Suave   .....and I like my neighbors. Liquid gasoline ha...   Jan 16 2010, 10:02 AM
Rand   Personally, I wouldn't weld on a gas tank, eve...   Jan 16 2010, 10:06 AM
J P Stein   Personally, I wouldn't weld on a gas tank, ev...   Jan 16 2010, 11:00 AM
- Lo-Fi Version Time is now: 8th July 2025 - 08:50 PM
