Bruce Hinds |
V-8 madness ![]() ![]() ![]() Group: Members Posts: 755 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest ![]() |
Each time I've "pulled the engine and trans, I've lowered the car as much as possible with the wheels removed and unbolted the mounts with so it all sits on a dolly. Then raise the car and slide the mass out.
Harbor Freight has a motorcycle lift on sale. Has anyone used one of these for this process? If it could be rigged, it seems it would take a lot of work out of the jacking, and allignment issues. B |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
I use the HF ATV life & some home made fixturing. Pull or install a motor/trans
by my self if no help is available.....not a safe as with a buddy, but easy. Attached thumbnail(s) ![]() Attached image(s) ![]() |
burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,881 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
I use the HF ATV life & some home made fixturing. Pull or install a motor/trans by my self if no help is available.....not a safe as with a buddy, but easy. Harbor Freight has this different unit for $179. The red one above is $100. I am thinking this may work well for a V8 if rails are put on it to hold the engine cross bar and you lengthen it to balance the trans. The pump action would be at the back and clear the car. Lightweight Aluminum Motorcycle Lift. The pad is 12 inches long so the open area is around 12 inches. Quickly perform routine maintenance the easy way. * 1500 lb. maximum lift capacity * 4-1/2" minimum, 19" maximum height (with extensions) * Lightweight 46 lbs. * Extra wide base for stability * Rubber grip pads protect motorcycle frame (IMG:style_emoticons/default/idea.gif) Bob Burton http://www.harborfreightusa.com/usa/itemdi...submit2=find+it (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 1st September 2025 - 12:48 PM |
