| phoenixred |
Jan 10 2010, 02:43 PM
Newbie ![]() Group: Members Posts: 5 Joined: 21-May 09 From: North NJ Member No.: 10,387 Region Association: None |
IS this how one gets the idea to replace all the c/v joints?
I have been driving the wheels off the car this past year after getting things sorted. Way back when I cleaned and repacked/rebooted the c/vs and then went on to sort out other areas of car and not drive so much. This is different now. While today is very cold, this low frequency clunk when rolling off seems to be a harbinger of new parts to come. any thoughts? thanks Eric IT seems cv'sclunking and longs crunching have some sonic similarities. anyway I've confused the two here! |
| r_towle |
Jan 17 2010, 02:14 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Clunk when rolling? or a hum or whine when rolling?
Whine or clunk in reverse? Whine or clunk when turning one way or the other at speed? A clackity clack sound when turning tight at slow speed? All are CV joints. Clunk when starting off from a stand still First thing I check is all motor mounts, front a rear. The inner rubbers tends to break over time...those allow the engine to rise up and it clunks. Rear motor/trans mounts clunk and its hard to see them as bad...you need to pull them out to see a crack... If no motor mounting issues, its a CV joint. Also, make sure there is not some thing rolling around in the trunks...BTDT Rich |
phoenixred p/s/r drive train clunk,OR RUST Jan 10 2010, 02:43 PM
faux916 Sounds like a CV joint to me. Jan 10 2010, 03:18 PM
campbellcj Hard to say via long distance, but it might also b... Jan 10 2010, 04:20 PM
brp986s The 2 times I've had cv's go out there was... Jan 10 2010, 06:07 PM
phoenixred
The 2 times I've had cv's go out there wa... Jan 17 2010, 01:54 PM
phoenixred
Clunk when rolling? or a hum or whine when rollin... Jan 18 2010, 07:02 AM
Gint I'd edit the first post also. You'll cont... Jan 18 2010, 08:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 01:53 PM |
