> Narrow body fuch 7R fitment, anyone running fuch 7R wheels?
tomkirkcis
post Jan 23 2010, 10:38 AM
.I have been running searches for a couple of hours but can't find any info on fitment of 7r fuchs on a 914.
I have a narrow body 1970 factory 914-6 that has a hot 3.2SS motor and a close ratio LSD box Dr Evil built for me. It currently has 205/50 on 6 x 15 fuchs. Not enough tire .
I have some AA metal flairs I got in a group buy a couple of years ago that I inteneded to install. I have four 9 x 16 fuchs that I was going to install all around . Certainly would take care things
I am having second thoughts about installing flairs. It is just so much fun having a stock looking 914 with a big motor.
I have access to a set of 4 7r Fuchs with 225/50 Brigestones. These are the Fuchs with the large backspacing
Is anyone have 7Rs fitted to a narrow body?
What tires can you fit?
What spacers?
Thanks
Tom
dr914@autoatlanta.com
post Jan 23 2010, 10:44 AM
The seven rsr wheel fits great with a 205 but not 225 unless the fender lip is adjusted ruining the stock look
I would agree that if you have a nice car with a big engine keep the stock wheel wells. A real sleeper!
] On the other hand making a 914 into a GT clone is the rage these days much like the guys are doing with the 911 models turning them into an rs. The best candidates for this conversion are the 964 models.
I would not put 9 inch in the front only 7 inch. You do not need them and it will affect turn in.
QUOTE(tomkirkcis @ Jan 23 2010, 09:38 AM) *
What spacers?
Thanks
Tom
burton73
post Jan 23 2010, 12:55 PM
Senior member, and old dude
QUOTE(dr914@autoatlanta.com @ Jan 23 2010, 08:44 AM) *
What spacers?
Thanks
Tom
George,
I plan to run 8" 16 up front and 9" 16 in the back of my 6 #41 with your flares. Roll the lips and put an Elephant front turn limiter so the front tires do not scrape the inner fender wells. No spacers.
Tom,
The picture shown is of my V8 car with 7” x 16 Fuchs 911 offset. The lip is rolled. This car is getting 951 offset 7” and 8” Fuchs with 245 rears and 225 fronts.
There are pictures of people on this board running 8” 951 wheels with just a small bit of adjustment to the stock body. The 8” 951 look just like the 7” 911 wheel and need just the lip rolled. One of them will step up or you may find it in the search area. 8 rear 7 front
Bob
tomkirkcis   Narrow body fuch 7R fitment   Jan 23 2010, 10:38 AM
dr914@autoatlanta.com   The seven rsr wheel fits great with a 205 but not ...   Jan 23 2010, 10:44 AM
tomkirkcis   [quote name='dr914@autoatlanta.com' date=...   Jan 23 2010, 12:22 PM
dr914@autoatlanta.com   [quote name='dr914@autoatlanta.com' date=...   Jan 23 2010, 01:26 PM
burton73   The seven rsr wheel fits great with a 205 but not...   Jan 23 2010, 12:55 PM
underthetire   I have the large backspace 16X7 dials on my narrow...   Jan 23 2010, 10:51 AM
campbellcj   There are other options for flares besides the fac...   Jan 23 2010, 11:29 AM
tomkirkcis   I have a pair of 951 8 x 16 that I bought as a pos...   Jan 23 2010, 01:22 PM
burton73   Tom, This is a picture of sixnotfour car wit 245-...   Jan 23 2010, 02:56 PM
dr914@autoatlanta.com   Tom, This is a picture of sixnotfour car wit 245...   Jan 23 2010, 03:20 PM
brant   you actually might get the 225's depending on ...   Jan 23 2010, 05:53 PM
tomkirkcis   Thanks for posting the image. I am amazed 245 fit...   Jan 23 2010, 06:08 PM
burton73   8x16 Offset 23.3 (944) Backspace mm 120 95...   Jan 23 2010, 09:50 PM
Michael N   This chart help me when I was trying to decide whe...   Jan 23 2010, 10:32 PM
HaraldD   Hello! I`m driving 7"R Wheels all aro...   Jan 24 2010, 02:59 AM
qa1142   This chart help me when I was trying to decide wh...   Aug 14 2010, 12:16 PM
pete-stevers   3.2ss that is exactly what i am dreaming of buildi...   Jan 24 2010, 11:03 AM
tomkirkcis   Harald Your 914 is gorgeous. Thanks for posting t...   Jan 24 2010, 08:45 PM
tomkirkcis   Pete The engine has weber 46s with 40mm venturis,...   Jan 24 2010, 09:01 PM
pete-stevers   yup...sounds like a nasty lil machine, you will ne...   Jan 25 2010, 12:47 AM
messix   don't roll, use a thin cut off wheel on a die ...   Jan 25 2010, 01:22 AM
mskala   Tom, There is no one answer for widest rubber in t...   Jan 25 2010, 12:06 PM
sixaddict   On a conversion, I have currently mounted 16 X 7 w...   Jan 25 2010, 03:34 PM
burton73   On a conversion, I have currently mounted 16 X 7 ...   Jan 25 2010, 09:38 PM
Eric_Shea   Tom, I don't see the advantage of 7R's on...   Jan 25 2010, 05:41 PM
Michael N   Check out the article in Oct 2006 Excellence. It ...   Jan 25 2010, 06:42 PM
campbellcj   I just checked my car yesterday at the track and t...   Jan 25 2010, 07:53 PM
Eric_Shea   That would be the ticket. Have Harvey build a s...   Jan 25 2010, 09:41 PM
underthetire   I had 205's on my old rivi's. 5" rim ...   Jan 25 2010, 09:42 PM
javadog   I have a '71 six with 7R wheels on the back. ...   Jan 26 2010, 08:19 AM
burton73   I tried on the tires for size with the old trailin...   Jan 26 2010, 04:59 PM
burton73   I pulled down the tires that where on my car when ...   Jan 26 2010, 05:05 PM
pete-stevers   That would be the ticket. Have Harvey build a ...   Jan 26 2010, 07:09 PM
tomkirkcis   I have been traveling on business a ton, and was a...   Feb 13 2010, 04:02 PM
mskala   The safer and more complete way is to disconnect t...   Feb 13 2010, 05:36 PM
tomkirkcis   The safer and more complete way is to disconnect ...   Feb 15 2010, 06:26 PM
davesprinkle   The safer and more complete way is to disconnect...   Feb 15 2010, 10:03 PM
tomkirkcis   Here are a couple of images. Image of the 225/50 o...   Feb 13 2010, 09:14 PM
Eric_Shea   So, do they fit or do they rub? I would "at ...   Feb 15 2010, 12:02 PM
tomkirkcis   I do not know. Racer Chris at Tangerine Racing di...   Feb 16 2010, 06:23 PM
tomkirkcis   Well, we did some test fitting on the front. I nee...   Mar 7 2010, 04:03 PM
tomkirkcis   Wheel stud length? I am confused as to what is th...   Mar 13 2010, 06:22 PM
tomkirkcis   I have had a chance to drive the car a couple hund...   Aug 12 2010, 07:01 PM
qa1142   First, I want to say this thread rocks :headbange...   Aug 13 2010, 04:44 AM
tomkirkcis   First, I want to say this thread rocks :headbang...   Aug 13 2010, 04:43 PM
Bleyseng   I had fittment issues in the back with 15x7 cookie...   Aug 13 2010, 09:52 AM
qa1142   so these won't fit with 23 offset with? Size ...   Aug 13 2010, 11:45 AM
sixnotfour   Here you go , bolt on , be happ, and light in the ...   Aug 13 2010, 11:51 AM
Bleyseng   and real deep dish rims to boot!!   Aug 13 2010, 12:33 PM
- Lo-Fi Version Time is now: 8th December 2025 - 12:01 PM
