> case and head vents, do I need to run a breather box?
wayne1234
post Jan 22 2010, 11:23 PM
Ok dual webber carbed 2.0, I think the PO had the head vents running to a T then to the oil breather near the oil cap... Is this right?? I did a search and now I'm really confused,,,,
pbanders
post Jan 23 2010, 10:20 AM
Note that even the Tangerine solution, which is the best one I've seen for carb setups, doesn't provide the same function as the factory system does. The factory system is a true Positive Crankcase Ventilation (PCV) system, that uses intake manifold vacuum to scavenge crankcase vapors. The Tangerine system (and other passive breather systems) depend on crankcase pressure alone to transport vapor to the system. The factory system uses an active PCV Valve mounted on the oil filler box to manage the system across a wide range of intake manifold pressures and crankcase pressures. There's a writeup on this system at my web page below.
ME733
post Jan 23 2010, 01:45 PM
[quote name='pbanders' date='Jan 23 2010, 11:20 AM' post='1264867']
Note that even the Tangerine solution, which is the best one I've seen for carb setups, doesn't provide the same function as the factory system does. The factory system is a true Positive Crankcase Ventilation (PCV) system, that uses intake manifold vacuum to scavenge crankcase vapors. The Tangerine system (and other passive breather systems) depend on crankcase pressure alone to transport vapor to the system. The factory system uses an active PCV Valve mounted on the oil filler box to manage the system across a wide range of intake manifold pressures and crankcase pressures. There's a writeup on this system at my web page below................. (IMG:style_emoticons/default/popcorn[1].gif) .....THE INTERIOR of the air filter housing will have a negative pressure as the carburators....SUCK AIR. Therefore the tangerine system will work identical to the factory setup, providing positive crankcase ventilation....and as venting the crankcase is important, reguardless of RPM,s why would anyone want or need a pvc valve?. The easier the engine "breaths" the faster it will rev. up., and have (fewer leaks) which are mostly caused by excessive crankcase pressure. A very free breathing engine starts with some internal crankcase modifications. (IMG:style_emoticons/default/popcorn[1].gif) Murray
pbanders
post Jan 23 2010, 03:35 PM
QUOTE(ME733 @ Jan 23 2010, 12:45 PM) *
The interior of the filter area of an air filter system like the Tangerine system (common to all Weber/Dellorto systems) is not at low pressure, it's essentially at atmospheric pressure. Yes, there is a tiny pressure differential across the filter element (less than 5 mbar), but if the pressure difference was truly significant, you'd be choking the breathing of the engine. True low pressure is in the area below the throttle plates, in the case of a carb'ed setup, in the runners themselves. Note that this is true only in the case of closed throttle (idle) or part-load (low throttle angle) conditions. When the engine is at WOT, there's only about 20 mbar of difference between the local atmospheric pressure and the pressure below the throttle plate.
True positive crankcase ventilation requires manifold vacuum.
PCV valves operate to control the amount of manifold vacuum used for crankcase scavenging. If you simply hook up manifold vacuum to the crankcase, you've essentially opened a giant vacuum leak. Even if the crankcase is completely sealed, too much vacuum can have other negative effects. The PCV valve controls the vacuum level in the crankcase to avoid these issues.
wayne1234   case and head vents   Jan 22 2010, 11:23 PM
Cap'n Krusty   Dumb. No, make that stupid. What ever possessed ...   Jan 22 2010, 11:47 PM
wayne1234   This is a completly rebuilt engine I am just putti...   Jan 23 2010, 12:05 AM
rick 918-S   Someone will have photos for you. I wish I were as...   Jan 23 2010, 12:22 AM
Racer Chris   This is an install pic of the Tangerine Racing Bre...   Jan 23 2010, 05:30 AM
Cevan   I've seen these arrangements setup a couple of...   Jan 23 2010, 07:29 AM
Racer Chris   Is it necessary to use the spark arrestor that th...   Jan 23 2010, 08:37 AM
Gint   Link to a 914world search for +head +vent A searc...   Jan 23 2010, 09:06 AM
pbanders   Note that even the Tangerine solution, which is th...   Jan 23 2010, 10:20 AM
ME733   [quote name='pbanders' date='Jan 23 20...   Jan 23 2010, 01:45 PM
pbanders   THE INTERIOR of the air filter housing will have...   Jan 23 2010, 03:35 PM
ME733   THE INTERIOR of the air filter housing will hav...   Jan 24 2010, 07:24 AM
pbanders   .....................Well you have already explai...   Jan 24 2010, 11:29 AM
wayne1234   Man I hate to say it but the setup going back into...   Jan 23 2010, 08:54 PM
Racer Chris   Man I hate to say it but the setup going back int...   Jan 23 2010, 10:35 PM
Cevan   There being a ton of people on this forum running ...   Jan 24 2010, 08:06 AM
r_towle   Cevan, If you run the oil vapors into the carbs, ...   Jan 24 2010, 10:00 AM
Racer Chris   With the exit gases routed to the carbs, I have t...   Jan 24 2010, 11:17 AM
wayne1234   ok how about this.. I know an my Audi TT a common ...   Jan 24 2010, 10:53 PM
kg6dxn   You could do what the V8 drag racers use. Crank ca...   Jan 24 2010, 11:24 PM
ME733   You could do what the V8 drag racers use. Crank c...   Jan 26 2010, 08:20 AM
johnnie5   Here are a few pics of my CB/Empi setup.... seems ...   Jan 26 2010, 09:56 AM
Cap'n Krusty   Rich Towle said earlier, "Older American cars...   Jan 26 2010, 11:06 AM
ME733   Rich Towle said earlier, "Older American car...   Jan 27 2010, 11:57 AM
DBCooper   Rich Towle said earlier, "Older American car...   Jan 27 2010, 01:20 PM
Gint   While I understand your point John and I agree wit...   Jan 26 2010, 12:41 PM
Cap'n Krusty   While I understand your point John and I agree wi...   Jan 27 2010, 01:58 PM
pbanders   [quote name='Gint' post='1265870' date='Jan 26 20...   Jan 27 2010, 03:29 PM
Gint   [quote name='Gint' post='1265870' date='Jan 26 20...   Jan 27 2010, 10:20 PM
underthetire   [quote name='Gint' post='1265870' date='Jan 26 20...   Feb 1 2010, 05:03 PM
HAM Inc   Oil runs cooler and returns to the crankcase faste...   Jan 27 2010, 12:36 PM
bandjoey   Oil runs cooler and returns to the crankcase fast...   Jan 27 2010, 06:04 PM
sean_v8_914   just drive across the border and you will experien...   Jan 27 2010, 05:45 PM
jaxdream   Oil runs cooler and returns to the crankcase fas...   Jan 27 2010, 06:14 PM
HAM Inc   It does do something; it slows the return of oil ...   Jan 28 2010, 08:58 AM
John Jentz   It does do something; it slows the return of oil...   Jan 28 2010, 09:31 AM
luvatenor   It does do something; it slows the return of oi...   Feb 1 2010, 09:49 AM
Jake Raby   It does do something; it slows the return of oil...   Feb 2 2010, 11:55 AM
bandjoey   NO VENTS? :popcorn:   Feb 1 2010, 11:35 PM
jaxdream   Ok , Len I'll give it a shot ( I am not an eng...   Feb 1 2010, 11:57 PM
ME733   ,,,,,,,,,,,,,USE THE DAMN HEAD VENTS.........MURRA...   Feb 2 2010, 09:40 AM
rhcb914   Well if the oil is staying in the heads for a long...   Feb 2 2010, 09:40 AM
ME733   ..........USE THE DAMN HEAD VENTS.....Because, the...   Feb 2 2010, 10:09 AM
HAM Inc   Bingo! Now put some thought into why the oil ...   Feb 2 2010, 11:36 AM
Cevan   I can see why with a vented head, oil in that area...   Feb 2 2010, 01:03 PM
Jake Raby   With less head breathing from the valve covers the...   Feb 2 2010, 01:23 PM
HAM Inc   The pressure in the crankcase at large is generate...   Feb 2 2010, 01:53 PM
Cevan   I see that the 1.8 L-Jet motor uses a 22mm hose fr...   Feb 2 2010, 01:55 PM
ME733   ............What in the hell...!!!...   Feb 2 2010, 03:45 PM
HAM Inc   I'm not intersted in argueing with anyone, but...   Feb 2 2010, 05:01 PM
bandjoey   Letter from a getting old fart. Dear Murray: Thi...   Feb 2 2010, 05:12 PM
jaxdream   Ok , Len , I came out of the rootcellar , don...   Feb 2 2010, 05:15 PM
Gint   Ok , Len , I came out of the rootcellar , don...   Feb 3 2010, 07:37 AM
jaxdream   Mods , don't lock this thread yet ...... Jack...   Feb 2 2010, 05:18 PM
bandjoey   Ditto's. More. Vent it from the chimney means...   Feb 2 2010, 05:21 PM
ME733   Ditto's. More. Vent it from the chimney mean...   Feb 2 2010, 06:15 PM
Cevan   Ditto's. More. Vent it from the chimney mean...   Feb 2 2010, 07:36 PM
bandjoey   Ditto's. More. Vent it from the chimney mea...   Feb 2 2010, 07:41 PM
Jake Raby   WOW, another one of those guys that have continu...   Feb 2 2010, 08:46 PM
Jake Raby   BTW- Murray which Type 4 engines came from the fac...   Feb 2 2010, 08:52 PM
johnnie5   :popcorn:   Feb 2 2010, 09:19 PM
jaxdream   Ok, Jake and / or Len , would a setup running off...   Feb 2 2010, 11:24 PM
ME733   ..........Ok , I shall continue to point out the a...   Feb 3 2010, 08:47 AM
HAM Inc   A single central vent from the chimney needs to be...   Feb 3 2010, 08:51 AM
Jake Raby   I was expecting a much more dramatic reply from Mu...   Feb 3 2010, 09:05 AM
HAM Inc   You know Murray, for a guy who was building engine...   Feb 3 2010, 09:14 AM
type11969   And I will point out to you that I have nothing t...   Feb 3 2010, 09:27 AM
ME733   You know Murray, for a guy who was building engin...   Feb 3 2010, 09:51 AM
type11969   Murray ? ? ? ? what would Jake and Len have to gai...   Feb 3 2010, 09:24 AM
Jake Raby   Murray ? ? ? ? what would Jake and Len have to ga...   Feb 3 2010, 09:31 AM
type11969   .....:popcorn: thanks :popcorn:......   Feb 3 2010, 09:34 AM
Jake Raby   You know... Last night after Murray made his comme...   Feb 3 2010, 11:01 AM
Rand   Murray, put your money where your mouth is. Build...   Feb 3 2010, 11:02 AM
HAM Inc   Good work Jake! But I can't but help wonde...   Feb 3 2010, 12:13 PM
ME733   Good work Jake! But I can't but help wond...   Feb 3 2010, 04:28 PM
wayne1234   Wow, I just wanted to clean up my engine bay, Jake...   Feb 3 2010, 02:33 PM
Jake Raby   Wow, I just wanted to clean up my engine bay, Jak...   Feb 3 2010, 02:37 PM
ME733   ...Well jake arn't you special. Just like the ...   Feb 3 2010, 03:52 PM
McMark   If you care to continue the debate, take it into P...   Feb 3 2010, 04:18 PM
HAM Inc   :trophy: Great call McMark.   Feb 3 2010, 04:25 PM
Jake Raby   McMark is right. Murray, if you want to keep argui...   Feb 3 2010, 04:47 PM
ME733   McMark is right. Murray, if you want to keep argu...   Feb 3 2010, 06:38 PM
Jake Raby   McMark is right. Murray, if you want to keep arg...   Feb 3 2010, 08:01 PM
SirAndy   :sleep: What did i miss? :chow:   Feb 3 2010, 04:48 PM
HAM Inc   Nothing go back to sleep!   Feb 3 2010, 05:58 PM
Twystd1   This is a great thread. I am learning a lot about...   Feb 3 2010, 06:10 PM
ME733   ..........Well the only thing you missed was ... a...   Feb 3 2010, 06:33 PM
r_towle   Some people built racing motors before the Interne...   Feb 3 2010, 08:28 PM
pbanders   So, Early Djet has head vents. Later Djet does no...   Feb 3 2010, 10:03 PM
904svo   They had to meet the EPA requirements on Hyro carb...   Feb 3 2010, 09:06 PM
jaxdream   <_< Jack / jaxdream   Feb 3 2010, 11:55 PM
luvatenor   Hi- I have a single Weber conversion. Where would ...   Feb 4 2010, 05:03 AM
McMark   The vents on the oil filler and the heads (if appl...   Feb 4 2010, 05:28 PM
ConeDodger   Wow. I guess we have figured out how to get a lot ...   Feb 4 2010, 05:51 PM
HAM Inc   Who's pissed? I have nothing but love for eve...   Feb 5 2010, 10:37 AM
ConeDodger   Who's pissed? I have nothing but love for ev...   Feb 5 2010, 10:45 AM
ME733   ............Good grief.....the number of brainwash...   Feb 5 2010, 11:16 AM
rtalich   ............Good grief.....the number of brainwas...   Feb 5 2010, 11:50 AM
ME733   ............Good grief.....the number of brainwa...   Feb 5 2010, 12:29 PM
HAM Inc   Rob your heads will be front and center here shor...   Feb 5 2010, 12:16 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:32 PM
