| siverson |
Jan 20 2010, 06:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,464 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California
I'm just curious...
I put new seals on my six when I restored it, it I'd say it leaks a little. Definitely not dry, but livable. On my new [to me] 4, the seals *look* ok, but it leaks horribly. If I park outside, I can literally get puddles of water on the floor (both sides, in front and behind the seats). -Steve |
| phoenixred |
Jan 24 2010, 11:36 PM
Newbie ![]() Group: Members Posts: 5 Joined: 21-May 09 From: North NJ Member No.: 10,387 Region Association: None |
I too needed rubber parts, put all except the upper & two lower targas, and the two inner door seals. I wonder what the new parts are...I think the cabin parts were all Porsche. Perfect fit, and worth the time. Prolly over 300$ easily for the less expensive seals.
My car is not anywhere near perfect margins etc. this is reflected in some near gaps here and there. definate drips off the "builtin" gutter in the top itself. If windows are cracked 1/2 inch better watch that gutter drip. default water source is pushed from the p/side rear wheel wash into the rear of the rusty floor pan. it was quite a big surprise when I first got the car on the road. now, with basic problem areas found and work around in place.(stuffed rusty floor pan with easily manipulated ropecaulk/almost like the electrician's putty to water seal cables on service entrances.easily removed or "helped" with more putty until the real repair arrives (IMG:style_emoticons/default/welder.gif) meanwhile this NJ car has a daily driver's life (IMG:style_emoticons/default/driving.gif) it's great! |
siverson How much does your car leak when it rains? Jan 20 2010, 06:04 PM
siverson Ooops, I messed up the poll. Oh well. Jan 20 2010, 06:05 PM
underthetire I think you forgot Monsoon inside the car vote. Jan 20 2010, 06:07 PM
SirAndy I think you forgot Monsoon inside the car vote.
:... Jan 20 2010, 06:26 PM
jsayre914 I also replaced the famous 3 part seal and the low... Jan 20 2010, 06:08 PM
Mikey914
I also replaced the famous 3 part seal and the lo... Jan 21 2010, 04:31 AM
Phoenix 914-6GT :evilgrin: Okay, mine is only dry as a bone when i... Jan 20 2010, 06:31 PM
Porcharu Rear window is loose - lots of leaks and standing ... Jan 20 2010, 06:38 PM
SLITS I carry a bar of soap for my bi-annual bath. Jan 20 2010, 06:39 PM
7275914911 Drivers side would get "A Little" vote B... Jan 20 2010, 06:56 PM
Pat Garvey Mine is a 2, that I bought new.
Never leaked a dr... Jan 20 2010, 07:50 PM
Joe Owensby Put in a total new set of rubber from AA a few yea... Jan 20 2010, 08:52 PM
ppeters914
Just needs good rubber and proper alignment of th... Jan 25 2010, 12:31 PM
sww914 The inside of my ears stay clean if I drive it in ... Jan 20 2010, 09:04 PM
Vacca Rabite Rain is wet, so I don't let my car see it.
Za... Jan 20 2010, 09:49 PM
jd74914 My car is surprisingly leak free. I'm consiste... Jan 20 2010, 10:34 PM
Elliot Cannon Drive fast. :driving: Don't stop. :driving: ... Jan 21 2010, 12:02 AM
SLITS
Drive fast. :driving: Don't stop. :driving:... Jan 21 2010, 11:18 AM
Sleepin
Drive fast. :driving: Don't stop. :driving... Jan 23 2010, 04:17 PM
hot_shoe914 mine leaks the same amount of oil whether it is ra... Jan 21 2010, 12:18 AM
Middlefour I always thought that if they did'nt leak you ... Jan 21 2010, 02:07 AM
siverson > would puddle if not for the carpet
My red ca... Jan 21 2010, 03:50 AM
tat2dphreak I need seals, I can stick fingers into the cab at ... Jan 21 2010, 10:07 AM
RobW I tried to winterize my former race car with tape ... Jan 21 2010, 11:17 AM
bandjoey Until I Mikeysized the rubber, it leaked. I'm... Jan 21 2010, 12:22 PM
jhadler Not a drop! Then again, it helps that it's... Jan 21 2010, 01:41 PM
al weidman I don't want to find out, no rust so far. Jan 21 2010, 08:40 PM
szuccaro no leaks because I dont drive it in the rain. :... Jan 23 2010, 12:06 AM
Heeltoe914 Well its in the garage most of the rainny days, so... Jan 23 2010, 11:06 AM
Rod Mine doesn't leak at all :Qarl:
It is annoy... Jan 23 2010, 12:08 PM
azbill My car never leaks. It lives in Arizona and never ... Jan 24 2010, 10:21 AM
SUNAB914 :popcorn: Beautiful rear trunck above! 74 hol... Jan 24 2010, 07:26 PM
charliew I bet the rear window is loose in every 914 that h... Jan 25 2010, 10:43 AM
9146986 Shamless plug. This will keep the interior of you... Jan 25 2010, 06:06 PM
gothspeed
Shamless plug. This will keep the interior of yo... Feb 1 2010, 08:22 PM
mikerose
Shamless plug. This will keep the interior of yo... Feb 2 2010, 03:04 PM
Kirmizi
:agree:
One of the best investments I've ma... Feb 1 2010, 03:40 PM
gopack I voted "none" because it never rains i... Feb 6 2010, 12:05 PM
J P Stein I had a 58 Vette....with a hardtop some years back... Feb 6 2010, 12:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 02:58 AM |
