Trouble shooting a 2.2 / 6 cyl, Starting up |
drew5785 |
Jan 28 2010, 12:05 AM
Newbie Group: Members Posts: 5 Joined: 27-January 10 From: brea,ca Member No.: 11,299 Region Association: Southern California |
I've recently swapped the motor on my 914 from a 1.7-4 to a 2.2-6cyl. This is my first porsche so I'm not an expert. Let me explain my problem:
I've swapped the motor, hooked up all the wires and plumbing. But it wont start. I've worked on other cars before so I've gone through the basics. Its getting gas, it turns over fine, and seems to be getting plenty of spark. But no bang. My only thought is that the timing is off. I've heard that you have to crank the motor tell the notch in the front pulley is at 12:00 then check that the rotor is pointing to the number one wire. Anyone thats worked on a 914-6 knows how impossible it is to really work on the front pulley. From what I can tell the timing is right too. Anyone have any tips or ideas. I dont want to give in and take it to a thief...I mean mechanic. |
IronHillRestorations |
Jan 28 2010, 06:54 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Nice project! There could be a number of reasons your engine won't run, so you need to start from square one. The engine has to rotate twice to get #1 cylinder to TDC.
Double check the following and make sure it's dead on the nuts. Valve lash Cam timing Ignition timing Spark plug gap |
Lo-Fi Version | Time is now: 1st June 2024 - 10:49 AM |
