How do you get the wheel hub out? |
silverteener |
Feb 2 2010, 09:05 AM
Member Group: Members Posts: 214 Joined: 9-August 05 From: East Moline, IL Member No.: 4,566 |
I want to check and probably replace my rear wheel bearings but I need to remove the wheel hub. The haynes books shows it being driven out with a hammer and piece of metal pipe but I can't tell what diameter pipe to use. Anyone have any tips on getting the hubs out. thanks (IMG:style_emoticons/default/beerchug.gif) |
dr914@autoatlanta.com |
Feb 2 2010, 09:13 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I want to check and probably replace my rear wheel bearings but I need to remove the wheel hub. The haynes books shows it being driven out with a hammer and piece of metal pipe but I can't tell what diameter pipe to use. Anyone have any tips on getting the hubs out. thanks (IMG:style_emoticons/default/beerchug.gif) after removing the caliper the rotor and the cv axle, we usually drive the hub out with a brass drift tapping around the perimeter. A little lube helps. |
Lo-Fi Version | Time is now: 3rd June 2024 - 09:46 AM |
