| wayne1234 |
Jan 22 2010, 11:23 PM
Member ![]() ![]() Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None |
Ok dual webber carbed 2.0, I think the PO had the head vents running to a T then to the oil breather near the oil cap... Is this right?? I did a search and now I'm really confused,,,,
| HAM Inc |
Feb 3 2010, 09:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
You know Murray, for a guy who was building engines when Jake was pooping yellow you sure have a weak grasp of theory.
Oil cools the valve springs, not air. But I will concede that in as much as the heat that the oil draws from the springs and rockers is generated by the heads one could accurately state that the oil does cool the heads. But it's BTU absorbing capacity is not up to the task of drawing a significant amount of heat out of the heads, so it only benefits the springs and rockers. Which brings me back the point about unvented heads running slightly cooler oil temps. I'm not interested in going down the line point by point by point with you as you clearly have made up your mind. But I will point out one commonly held misconception that you suffer with yourself, further indicating that your understanding of engine theory is very elementary. QUOTE Hotter the springs=loss in valve seat pressure.=shorter valve spring effective pressure/life. Ok .(solution)..so just increase installed seat pressure..=...that increases rotational force...just to turn over the engine. (use torque wrench to conferm.). The cam loading at speed is nothing like what it is at assembly. At near redline speeds the load on the cam at max lift (as the lifter goes over the nose of the lobe) may be 5 lb's it may be near 0. At speed the greatest load that the cam sees is when the lobe encounters the stationary valve train and has to get it moving...and in a hurry. This is why higher rev engines want a higher spring rate (not to be confused with seat or open pressures). And it is why turning an engine over with a torque wrench to gain some understanding of the value of different spring rates AND pressures is useless. I pass this forward not to educate you (you already know it all) but to inform the community at large who have a real interest in these things and because they are not experts like you are willing to learn. I have not stepped in in the past when you have made post' that spread misinformation, it's just not my style, but on this subject you have attacked my credibility and the findings of an exhaustive study done by professionals. And I will point out to you that I have nothing to gain if people vent or don't vent their heads. I'm not selling breather systems. Folks be very wary of taking advise from this guy. |
| type11969 |
Feb 3 2010, 09:27 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
wayne1234 case and head vents Jan 22 2010, 11:23 PM
Cap'n Krusty Dumb. No, make that stupid. What ever possessed ... Jan 22 2010, 11:47 PM
wayne1234 This is a completly rebuilt engine I am just putti... Jan 23 2010, 12:05 AM
rick 918-S Someone will have photos for you. I wish I were as... Jan 23 2010, 12:22 AM
Racer Chris This is an install pic of the Tangerine Racing Bre... Jan 23 2010, 05:30 AM
Cevan I've seen these arrangements setup a couple of... Jan 23 2010, 07:29 AM
Racer Chris
Is it necessary to use the spark arrestor that th... Jan 23 2010, 08:37 AM
Gint Link to a 914world search for +head +vent
A searc... Jan 23 2010, 09:06 AM
pbanders Note that even the Tangerine solution, which is th... Jan 23 2010, 10:20 AM
ME733 [quote name='pbanders' date='Jan 23 20... Jan 23 2010, 01:45 PM
pbanders
THE INTERIOR of the air filter housing will have... Jan 23 2010, 03:35 PM
ME733
THE INTERIOR of the air filter housing will hav... Jan 24 2010, 07:24 AM
pbanders
.....................Well you have already explai... Jan 24 2010, 11:29 AM
wayne1234 Man I hate to say it but the setup going back into... Jan 23 2010, 08:54 PM
Racer Chris
Man I hate to say it but the setup going back int... Jan 23 2010, 10:35 PM
Cevan There being a ton of people on this forum running ... Jan 24 2010, 08:06 AM
r_towle Cevan,
If you run the oil vapors into the carbs, ... Jan 24 2010, 10:00 AM
Racer Chris
With the exit gases routed to the carbs, I have t... Jan 24 2010, 11:17 AM
wayne1234 ok how about this.. I know an my Audi TT a common ... Jan 24 2010, 10:53 PM
kg6dxn You could do what the V8 drag racers use. Crank ca... Jan 24 2010, 11:24 PM
ME733
You could do what the V8 drag racers use. Crank c... Jan 26 2010, 08:20 AM
johnnie5 Here are a few pics of my CB/Empi setup.... seems ... Jan 26 2010, 09:56 AM
Cap'n Krusty Rich Towle said earlier, "Older American cars... Jan 26 2010, 11:06 AM
ME733
Rich Towle said earlier, "Older American car... Jan 27 2010, 11:57 AM
DBCooper
Rich Towle said earlier, "Older American car... Jan 27 2010, 01:20 PM
Gint While I understand your point John and I agree wit... Jan 26 2010, 12:41 PM
Cap'n Krusty
While I understand your point John and I agree wi... Jan 27 2010, 01:58 PM
pbanders
[quote name='Gint' post='1265870' date='Jan 26 20... Jan 27 2010, 03:29 PM
Gint
[quote name='Gint' post='1265870' date='Jan 26 20... Jan 27 2010, 10:20 PM
underthetire
[quote name='Gint' post='1265870' date='Jan 26 20... Feb 1 2010, 05:03 PM
HAM Inc Oil runs cooler and returns to the crankcase faste... Jan 27 2010, 12:36 PM
bandjoey
Oil runs cooler and returns to the crankcase fast... Jan 27 2010, 06:04 PM
sean_v8_914 just drive across the border and you will experien... Jan 27 2010, 05:45 PM
jaxdream
Oil runs cooler and returns to the crankcase fas... Jan 27 2010, 06:14 PM
HAM Inc
It does do something; it slows the return of oil ... Jan 28 2010, 08:58 AM
John Jentz
It does do something; it slows the return of oil... Jan 28 2010, 09:31 AM
luvatenor
It does do something; it slows the return of oi... Feb 1 2010, 09:49 AM
Jake Raby
It does do something; it slows the return of oil... Feb 2 2010, 11:55 AM
bandjoey NO VENTS?
:popcorn: Feb 1 2010, 11:35 PM
jaxdream Ok , Len I'll give it a shot ( I am not an eng... Feb 1 2010, 11:57 PM
ME733 ,,,,,,,,,,,,,USE THE DAMN HEAD VENTS.........MURRA... Feb 2 2010, 09:40 AM
rhcb914 Well if the oil is staying in the heads for a long... Feb 2 2010, 09:40 AM
ME733 ..........USE THE DAMN HEAD VENTS.....Because, the... Feb 2 2010, 10:09 AM
HAM Inc
Bingo! Now put some thought into why the oil ... Feb 2 2010, 11:36 AM
Cevan I can see why with a vented head, oil in that area... Feb 2 2010, 01:03 PM
Jake Raby With less head breathing from the valve covers the... Feb 2 2010, 01:23 PM
HAM Inc The pressure in the crankcase at large is generate... Feb 2 2010, 01:53 PM
Cevan I see that the 1.8 L-Jet motor uses a 22mm hose fr... Feb 2 2010, 01:55 PM
ME733 ............What in the hell...!!!... Feb 2 2010, 03:45 PM
HAM Inc I'm not intersted in argueing with anyone, but... Feb 2 2010, 05:01 PM
bandjoey Letter from a getting old fart.
Dear Murray: Thi... Feb 2 2010, 05:12 PM
jaxdream Ok , Len , I came out of the rootcellar , don... Feb 2 2010, 05:15 PM
Gint Ok , Len , I came out of the rootcellar , don... Feb 3 2010, 07:37 AM
jaxdream Mods , don't lock this thread yet ......
Jack... Feb 2 2010, 05:18 PM
bandjoey Ditto's. More.
Vent it from the chimney means... Feb 2 2010, 05:21 PM
ME733
Ditto's. More.
Vent it from the chimney mean... Feb 2 2010, 06:15 PM
Cevan
Ditto's. More.
Vent it from the chimney mean... Feb 2 2010, 07:36 PM
bandjoey
Ditto's. More.
Vent it from the chimney mea... Feb 2 2010, 07:41 PM
Jake Raby
WOW, another one of those guys that have continu... Feb 2 2010, 08:46 PM
Jake Raby BTW- Murray which Type 4 engines came from the fac... Feb 2 2010, 08:52 PM
johnnie5 :popcorn: Feb 2 2010, 09:19 PM
jaxdream Ok, Jake and / or Len , would a setup running off... Feb 2 2010, 11:24 PM
ME733 ..........Ok , I shall continue to point out the a... Feb 3 2010, 08:47 AM
HAM Inc A single central vent from the chimney needs to be... Feb 3 2010, 08:51 AM
Jake Raby I was expecting a much more dramatic reply from Mu... Feb 3 2010, 09:05 AM
ME733
You know Murray, for a guy who was building engin... Feb 3 2010, 09:51 AM
type11969 Murray ? ? ? ? what would Jake and Len have to gai... Feb 3 2010, 09:24 AM
Jake Raby
Murray ? ? ? ? what would Jake and Len have to ga... Feb 3 2010, 09:31 AM
type11969 .....:popcorn: thanks :popcorn:...... Feb 3 2010, 09:34 AM
Jake Raby You know...
Last night after Murray made his comme... Feb 3 2010, 11:01 AM
Rand
Murray, put your money where your mouth is. Build... Feb 3 2010, 11:02 AM
HAM Inc Good work Jake! But I can't but help wonde... Feb 3 2010, 12:13 PM
ME733
Good work Jake! But I can't but help wond... Feb 3 2010, 04:28 PM
wayne1234 Wow, I just wanted to clean up my engine bay, Jake... Feb 3 2010, 02:33 PM
Jake Raby
Wow, I just wanted to clean up my engine bay, Jak... Feb 3 2010, 02:37 PM
ME733 ...Well jake arn't you special. Just like the ... Feb 3 2010, 03:52 PM
McMark If you care to continue the debate, take it into P... Feb 3 2010, 04:18 PM
HAM Inc
:trophy:
Great call McMark. Feb 3 2010, 04:25 PM
Jake Raby McMark is right. Murray, if you want to keep argui... Feb 3 2010, 04:47 PM
ME733
McMark is right. Murray, if you want to keep argu... Feb 3 2010, 06:38 PM
Jake Raby
McMark is right. Murray, if you want to keep arg... Feb 3 2010, 08:01 PM
SirAndy :sleep:
What did i miss? :chow: Feb 3 2010, 04:48 PM
HAM Inc Nothing go back to sleep! Feb 3 2010, 05:58 PM
Twystd1 This is a great thread.
I am learning a lot about... Feb 3 2010, 06:10 PM
ME733 ..........Well the only thing you missed was ... a... Feb 3 2010, 06:33 PM
r_towle Some people built racing motors before the Interne... Feb 3 2010, 08:28 PM
pbanders
So, Early Djet has head vents.
Later Djet does no... Feb 3 2010, 10:03 PM
904svo They had to meet the EPA requirements on Hyro carb... Feb 3 2010, 09:06 PM
jaxdream <_<
Jack / jaxdream Feb 3 2010, 11:55 PM
luvatenor Hi- I have a single Weber conversion. Where would ... Feb 4 2010, 05:03 AM
McMark The vents on the oil filler and the heads (if appl... Feb 4 2010, 05:28 PM
ConeDodger Wow. I guess we have figured out how to get a lot ... Feb 4 2010, 05:51 PM
HAM Inc
Who's pissed? I have nothing but love for eve... Feb 5 2010, 10:37 AM
ConeDodger
Who's pissed? I have nothing but love for ev... Feb 5 2010, 10:45 AM
ME733 ............Good grief.....the number of brainwash... Feb 5 2010, 11:16 AM
rtalich
............Good grief.....the number of brainwas... Feb 5 2010, 11:50 AM
ME733
............Good grief.....the number of brainwa... Feb 5 2010, 12:29 PM
HAM Inc
Rob your heads will be front and center here shor... Feb 5 2010, 12:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:03 PM |
