| skiking |
Sep 16 2009, 09:28 PM
Newbie ![]() Group: Members Posts: 23 Joined: 15-September 09 From: Rapid City Member No.: 10,811 Region Association: None |
I recently had the brake calipers and lines replaced on my '75 teener. When I got it back from the shop, the brake warning flasher light was on all the time. The shop said they tried to fix it, but i'm not sure they knew what they were doing.
The pedal feels a little soft, but the brakes work and the reservoir is full. Any ideas what could be causing the brake warning light to flash whenever the car is running? Thanks, Robbie |
| bdstone914 |
Sep 17 2009, 02:10 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,206 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If your master cylinder does not have a reset on the outside, you need to pull the switch out of the master cylinder and there will be a button on the inside of the switch for you to press to reset it.
| flat4 |
Sep 17 2009, 06:31 PM
Member ![]() ![]() Group: Members Posts: 120 Joined: 13-December 07 From: Australia Member No.: 8,459 |
If your master cylinder does not have a reset on the outside, you need to pull the switch out of the master cylinder and there will be a button on the inside of the switch for you to press to reset it. (IMG:style_emoticons/default/unsure.gif) Will the fluid leak out, or more importantly air get in, when I do this? Cheers, Steve |
| mpoffers |
Feb 6 2010, 01:42 PM
Member ![]() ![]() Group: Members Posts: 52 Joined: 15-September 08 From: Portland, OR Member No.: 9,551 Region Association: Pacific Northwest |
I'm in the same boat. Single brown wire, no reset button. The switch itself threads into the MC. Can I just take it out? I'd rather not do something stupid and spend the rest of the afternoon bleeding all 4 corners. Thanks, Mike If your master cylinder does not have a reset on the outside, you need to pull the switch out of the master cylinder and there will be a button on the inside of the switch for you to press to reset it. (IMG:style_emoticons/default/unsure.gif) Will the fluid leak out, or more importantly air get in, when I do this? Cheers, Steve |
skiking Brake warning light problem Sep 16 2009, 09:28 PM
zx-niner
I recently had the brake calipers and lines repla... Sep 16 2009, 10:10 PM
Rod
I recently had the brake calipers and lines repl... Sep 17 2009, 06:32 AM
flat4
Believe it or not, there is a re-set switch on t... Sep 17 2009, 07:04 AM
jt914-6
[quote name='Rod' post='1215466' date='Sep 17 200... Sep 17 2009, 05:52 PM
skiking
I recently had the brake calipers and lines repl... May 31 2010, 06:28 PM
marks914 Push your e-brake handle all the way down.
Mark Sep 17 2009, 02:05 PM
jsayre914
Mark
... Sep 17 2009, 06:15 PM
skiking
If your master cylinder does not have a reset on ... May 31 2010, 06:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 11:26 AM |
