| TheCabinetmaker |
Feb 6 2010, 02:30 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I copied this from the other site. I haven't been on either forum for the last year, so I posted it there, but then I see there was only 7 people loged on there and 200 here. WOW! I guess I missed something, huh?(IMG:style_emoticons/default/confused24.gif) Anyway, here it is.
Got another 914 with a story. I met a guy about ten years ago with one of the roughest 914's I'd seen. The paint was faded, it had a 34 weber, smoked rolled out the tail pipe, Half the parts weren't even 914 parts. The engine lid had some kinda ford truck hinges. I could write a short book. We became good friends and slowly but surely I got the car to be a dependable daily driver for him (60 miles everyday). We replaced all the missing and improper parts, rebuilt the 1.7L, found a good FI, Turbo tie rods, new brakes and MC, color sanded the paint, new ss gas lines. trunk floor replacement, etc. He then decided to return it to its original white color. He found a guy to do the job, and half way thru the paint job the painter decides he wants to buy it from my friend. They made a deal, and my friend bought a 911 targa. Haven't seen the car since it went to the body shop and get a call a few days ago that the guy who bought it had finished painting it but had lost interest in it and just wanted it out of his shop. I got the car for the wrecker fee!!!!! The car has been about half dismantled. Interior is stripped, most of the rubber was pulled off, and about everything else that needed to be removed for paint. At least he painted it completly. Door jambs, inside trunks, wheel wells, The engine bay was never painted red on the first repaint, so they didn't pull the engine. What I can't figure out is why they removed the relay board and fuse box from a running vehicle? I put a new relay board in it and a battery. Turned the key and nothing. Starter and engine turn by jumping solenoid. 14 pin connector has power at 14 and 12 pins, there is power to the fuse box, but no power at the #9 fuse, and #8 pin at the 14 pin connection. Where to look next? Key switch? I know if I hear it run, I'll get motivated to get her back on the road. |
| TheCabinetmaker |
Feb 6 2010, 03:52 PM
Make sure the harness connectors front and rear of the relay board are plugged in squarely (meaning not one set of pins off) then pry off both covers while leaving the plug installed. Put a working test light to pin 6 in the rear (yellow wire) crank the car and see if it lights. If so go to the yellow lead on the solenoid and repeat the test. If not go to the front connector pin 1 and repeat the test. If the light lights the relay board is bad. If not then it is the ign switch or if a 74 early 75 maybe the seat belt relay under the passenger seat. Already checked the #6 on the 12 pin. Nothing. I will check the front #1 tomorrow. Wouldn't no power at the #8 pin or at the #9 fuse indicate the key switch, or am I reading the schematic wrong? Welcome back! Sounds like a nice sore. Definitely check the ignition switch. And get post some pics! Thanks Gint, I've been hanging out at a bbq forum, but I think I'll be back more often. I'll post pics later today. |
vsg914 inherited an almost basket case Feb 6 2010, 02:30 PM
dr914@autoatlanta.com Make sure the harness connectors front and rear of... Feb 6 2010, 02:39 PM
Gint Welcome back! Sounds like a nice sore. Defin... Feb 6 2010, 03:02 PM
Rav914 ...sorry I misread something. Feb 6 2010, 03:38 PM
rick 918-S :wttc: (back)
:ttiwwp: Feb 6 2010, 05:27 PM
vsg914 Thanks Sir Rick. here ya go(if I can remember how ... Feb 6 2010, 05:46 PM
rick 918-S :clap: :boing: Nice score! Clean it up and tw... Feb 6 2010, 07:32 PM
kwales Good find!
Now, make it run.
What kind of wh... Feb 7 2010, 10:52 AM
vsg914 some kinda empi's i think Feb 7 2010, 12:02 PM
ClayPerrine Hey Curt... glad you are back..
Nice car. When ... Feb 7 2010, 09:58 PM
vsg914
Nice car. When... Feb 8 2010, 06:28 AM
vsg914 Ok, Nothing at #6 on 12pin conn, nothing on #1 on ... Feb 8 2010, 03:39 PM
vsg914 Woo-Hoo!!!!!! Making progr... Feb 9 2010, 01:00 PM
rick 918-S Based on the amount of work you did to the car whe... Feb 9 2010, 01:06 PM
vsg914 You nailed it Rick. I just wish he had called me i... Feb 9 2010, 01:15 PM
vsg914 Injectors are not opening, so no gas as of yet. Ti... Feb 9 2010, 02:19 PM
vsg914 Well, still have no gas. All looks right with the ... Feb 9 2010, 02:56 PM
vsg914 Oh boy, here we go. This morning I hooked up my fu... Feb 10 2010, 10:21 AM
vsg914 :Qarl: Persistance always wears down resistance... Feb 10 2010, 10:42 AM
rick 918-S WTG Curt! Glad you got it going! :headbang... Feb 10 2010, 01:47 PM
markb :headbanger: Feb 10 2010, 08:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:13 AM |
