| mepstein |
Feb 6 2010, 01:41 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,755 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
2 questions-
When I flare my car, I'm going from a 2.0 alloy 5.5x15 with 205x60x15 tires. I would like to keep the tire diameter the same on a 7x15 wheel and 225 tire. Would I use 50, 55 or 60 series tires? I think a 7 inch wheel and 225 tire might still have too much space between the tire and inside of the flare. Is there a spacer made that will fit a 4 lug wheel? I have read that the 4 lug hub takes a special lip on the wheel. Thanks, Mark |
| Eric_Shea |
Feb 6 2010, 10:58 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE If you can find a set of eights in the rear it would be better. Same tire size. AND you can use 21mm wheel spacers front and rear as well to really fill out the wells I assume you're talking 8" Fuchs? There is only one 8x15" (classic polished paddle, what we all refer to as a Fuchs) Fuchs. I double-dog dare you to get one, stick a 225/50x15 on there with a 21mm spacer and report back. I don't think that's going to happen. (IMG:style_emoticons/default/wink.gif) Mark, have you checked the tire calculator here on the site? Under 914 Info I believe. Handy tool. |
mepstein Another wheel, tire, flare question Feb 6 2010, 01:41 PM
dr914@autoatlanta.com
2 questions-
When I flare my car, I'm going ... Feb 6 2010, 02:29 PM
mepstein Ok, I appreciate the answer, it all makes sense an... Feb 6 2010, 05:50 PM
GeorgeRud I'd strongly recommend switching to the five l... Feb 6 2010, 06:17 PM
orange914
I'd strongly recommend switching to the five ... Feb 7 2010, 01:17 PM
mepstein I wanted to use Superlite wheels. I like the look.... Feb 6 2010, 08:14 PM
mepstein Didn't know about the tire calculator - thank ... Feb 7 2010, 09:51 AM
jimkelly you can get these in 4 lug 15" in varying wid... Feb 7 2010, 09:56 AM
carr914
I wanted to use Superlite wheels. I like the look... Feb 8 2010, 07:33 AM
mepstein Are the longer studs an off the shelf item?
So my... Feb 8 2010, 07:52 AM
carr914 No, but I would do 7&8s. Various Stud lengths ... Feb 8 2010, 09:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 03:08 AM |
